timing
Old Aug 15, 2009 | 08:20 PM
rjlazo34's Avatar
Car: 1992 Camaro Z28 25th Anniversary
Engine: 350ci w/ TPI
Transmission: 700 R-4 w/ shift kit
timing
what is the correct way to set timing on a 1992 L98 engine?
Old Aug 16, 2009 | 11:43 AM
customirocz's Avatar
Car: 86 Iroc-z
Engine: worked 350tpi
Transmission: built 700r4
Axle/Gears: auburn pos 4-10
Re: timing
I had gotten this advice from tpis on setting the base timing and worked for me.First get the motor hot, shut off motor disconnect the advance connector,start car adjust the timing to where you want it, shut car off disconnect the battery, reconnect the advance wire, wait five minutes reconnect battery and your good to go. If you miss the step of disconnct the battery like i had done it does not clear the memory for base timing out of the computer and will most likely give you a code 42 hope it works for you
Old Aug 18, 2009 | 04:25 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Re: timing
Did TPIS explain why the motor needs to be hot? I've never heard this before and never had a problem setting the timing on a cold motor.
Old Aug 18, 2009 | 05:26 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: timing
https://www.thirdgen.org/settingtiming
Old Aug 18, 2009 | 08:06 PM
Car: 86 Iroc-z
Re: timing
They did not tell me why the motor has to be hot but thats how i had always done it
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
