350 tpi roller rocker question 1.6/1.5?
Old Aug 18, 2009 | 09:20 PM
1b rock's Avatar
Transmission: a4
have a stock 350 tpi 90 iroc, car runs good for what it is but thinkin about putting a set of roller rockers on it.. since it has centerbolt valve covers i just wonder if there is any tricks to puttin rr under centerbolt valve covers... also what ratio would work best w my stock cam. going to spray the car also thanks
Old Aug 18, 2009 | 09:50 PM
profootbrake2's Avatar
Car: 92 Camaro Z28
Engine: ZZ4 TPI
Re: 350 tpi roller rocker question 1.6/1.5?
make sure you get roller rockers for center bolt valve covers not the wide ones for the older style covers
Old Aug 18, 2009 | 10:38 PM
mroth2008's Avatar
Car: 2001 Mazada Protege es
Engine: 2.0L dohc
Transmission: G-15m-r
Axle/Gears: 4.10
1.5 would be fine with a stock cam the 1.6 just gives you some more lift off the stock cam but it may be to much lift you would have to check the specs on the cam for travel and see 1.6 maybe too much I belive around .440 is the limit for stock heads
Old Aug 22, 2009 | 11:20 PM
1b rock's Avatar
Transmission: a4
who makes the narrow rockers
midge54
Dec 27, 2019 04:14 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
