Is 160 Stat hurting my ET?
Old Aug 27, 2009 | 08:52 PM
1970 Buick's Avatar
Car: 1989 GTA
So, I guess I should have done some research on here before putting in my 160 degree thermostat. Heck, I figured cooler engine, better performance. So after some reading on here, I see maybe it isn't a good idea. For what it's worth, I drive it maybe once a week, in summer months only. Maybe twice a month at the dragstrip. It is usually 90 or so degrees there on the pavement. So, should I switch to a 180? Like I siad, I only drive in the summers, which are about 80 to 90 degrees a day. Oh yea, I don't care about gas mileage.
Old Aug 27, 2009 | 10:28 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Is 160 Stat hurting my ET?
A 160 is on the cold side, but it's only the temp it opens at. The temp the fans are set to will have more to do with actual running temp (except when highway cruising).
Old Aug 28, 2009 | 10:09 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
usually a 160 stat will not go into closed loop withough some tunning done.... also that stat isnt really recommend for a daily driver.... 180 is the best for our cars......
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
