What is this? Picture
Old Aug 30, 2009 | 08:07 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
Does this thing have a name and a purpose? If so what and why?
Old Aug 30, 2009 | 08:14 PM
dwinhofer's Avatar
Car: 1985 Iroc Camaro, 1974 type LT Z28
Engine: modified L98 corvette, L82
Transmission: 700r4, Turbo 400
Axle/Gears: 3.42, 3.42 posi
Re: What is this? Picture
I was hoping someone would put that picture on here. I have the same one and was wondering what it was. I want to know what the two ports hook up to. One hooks up to throttle body I know but what does other one hook up to?
Old Aug 30, 2009 | 08:48 PM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
Please update your profile, we have no idea what type of 3rg Gen you have....Year, TPI, Carb, Auto, ECT....??
The part looks like a EGR Solenoid, one vac hose goes to the EGR valve and the other to the Throttle Body(see below for 1989 TPI)
Due a search on EGR and it should help you.....
Old Aug 30, 2009 | 08:58 PM
dwinhofer's Avatar
I have a 1985 tpi Iroc. I deleted my egr valve can I get rid of that part. I have it still plugged in and the line going to the throttle body is on it and hooked up. The other line that goes to egr is not plugged.
Old Aug 30, 2009 | 09:16 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Done and thanks
Old Aug 30, 2009 | 09:25 PM
Guest
Guest
Posts: n/a
If your EGR valve is gone, no need for the solenoid. Plug the end going to the EGR or take it all out and plug the TB.
Old Aug 31, 2009 | 12:26 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
dude, that part is sweet, shouldnt have to remove it. its required for visual inspection on smog here in cali, unless you checked out by a money grubbing service dude. That solenoid helps out a lot. ONE time i disconnected it. the rpms wouldnt come down after a burn out. that was scary. it pulses the egr valve that allow exhausted gases to enter the cylinders to help bring the rpm down. about 80percent non combustable. id recommend either getting a car without emissions and adding a 572 big block with supercharger to get power. because what i learned from messing with emission and parts stock, is that i 1. get in trouble, 2. could get in an accident from the rpms not coming down, or 3. tinkering with GM engineered engines. Im a good guy, i dont bash on others like the BMW board(gosh what snot heads) and itd cause more problems than fix. heres some link to cheer you up. www.rockauto.com www.free-tv-video-online.info
Old Aug 31, 2009 | 09:04 PM
dwinhofer's Avatar
I'm glad our emissions laws are not strict here in Montana.
Old Aug 31, 2009 | 09:42 PM
Guest
Guest
Posts: n/a
Uh, no it doesnt.
Old Aug 31, 2009 | 09:45 PM
dwinhofer's Avatar
Yeah that was a good one
Old Aug 31, 2009 | 10:47 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi all,
I really have to reply to this.
The EGR valve is a friend. What does it do? I help lowers the formation of N2O, reduces combustion temperature and slows down the combustion process. Thus pinging of the engine is prevented and the fual is completely burned. If you question do some reserch on the net. I have my EGR still operating on my 82 Bird with 350TPI getting around 27MPG.
Old Sep 1, 2009 | 05:32 PM
dwinhofer's Avatar
I was always told to get rid of egr valve. I still get good mileage with mine gone. I have only heard pinging of my engine when my timing was off.
Old Sep 1, 2009 | 05:48 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
As stated above with the wonderful diagram, it is the EGR vacuum control solenoid.
The EGR valve only opens at part throttle cruise at idle and WOT it is closed. It does not improve nor hurt fuel economy, it runs the exhaust through the combustion process again attemting to burn any unburnt fuel that makes it to the exhaust to emmision output. The best power gain from removing the EGR is the weight removal. Removing it from a stock ECU car actually pisses the computer off and keeps you in open loop so you get worse MPG anyway.
Old Sep 1, 2009 | 07:40 PM
Egg83's Avatar
Car: 85 Firebird
Engine: 355 Vortec TPI
Transmission: 700r4 with Pro-Built goodies
Axle/Gears: LS1 3.42 Posi Disc
There is alot of misinformation in this thread... For the sake of people in the future who may find this thread by searching.
The EGR valve or, Exhaust Gas Recirculation valve is applied by the computer to introduce inert exhaust gasses to the combustion process. This inert gas, by nature can no longer be used by the combustion process. Therefore it acts as a buffer. It partially fills the cylinder, along with the fuel and air mixture to bring down cylinder temperature to reduce the formation of the greenhouse gas NOx. In addition to this, it only functions when decelerating. So any claims to adverse performance is totally absurd unless the valve itself is faulty. -Bob
Old Sep 1, 2009 | 11:40 PM
"Uh, no it doesnt."-madmax
wanna bet. unplug the vac line to it, drive around.
Old Sep 1, 2009 | 11:44 PM
i heard if you get a chip programed. and set the EGR open speed to 199mph, it wont hurt.
Old Sep 1, 2009 | 11:49 PM
Guest
Guest
Posts: n/a
Sure, put your pink slip up. I can use a TA to sell.
There is more information in this whole post than can be captured in an entire novel. Even the correction post has at least one error, the EGR does not operate only under decel. Do a scan and take a look when the EGR is commanded.
Error two: NOx is not just one gas. NOx is to designate the various NO compounds formed during combustion.
Old Sep 2, 2009 | 07:56 AM
Egg83's Avatar
Car: 85 Firebird
Yes madmax, NOx is not a "gas", it is a compound of gasses. Oxides of nitrogen. Semantics. Correction 1.
As for the EGR application. Are you saying that the EGR is commanded during accelleration? If so, this would cause a driveability concern and cause the engine to stumble. -Bob
Old Sep 2, 2009 | 11:52 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
On OBD2 PCM/ECM, the EGR is infact open during acceleration. It is closed at idle. I can not verify it one way or the other at WOT.
It also does help on MPG. Depending upon your use and driving style, you may or may not notice, and how much.
Old Sep 2, 2009 | 12:29 PM
Guest
Guest
Posts: n/a
https://www.thirdgen.org/egrdiagnose
https://www.thirdgen.org/forums/tpi/...-function.html
Fronzizzle
Feb 9, 2017 09:31 AM
Linson
Sep 21, 2015 01:08 PM
okfoz
Sep 17, 2015 10:30 AM
Street Lethal
Sep 7, 2015 01:09 PM
Strick1
Sep 6, 2015 02:21 PM
