TPI Install in 90 Chevy 4X4
1990 Chevy K2500 4x4. 1991 Vette TPI motor. Engine swap, wiring is complete. Motor runs great until above 1/3 throttle, then dies on it's face. I am using the stock truck computer, which I think does not have enough power to open up the injectors all the way. Any plug an play ECM recommendations? Or any recommendations I can do to fix my problem
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: TPI Install in 90 Chevy 4X4
If staying with OBDI, you must use either the 1227165 ECM (86-89 TPI), the 1227730 ECM (90-92), or 1227727 ECM (90-91 Corvette). You can not use the truck TBI ECM.
If upgrading to OBDII, I would recommend the 12200411 PCM (01-02). As OBDII, you can use either single coil and Vortec distributor (01-02 Express Van calibration) or coil per cylinder (any LS1 type calibration).
I have a ECM/PROM from 1990 Firebird, plugs directly into the harness. All electrical works, but will not start. Is this because of an antitheift program in the ECM?
Your going to have to upgrade the fuel pump as well. If you have not done so already?? The stock tbi pump is only good for maybe 15psi and the Tpi needs at least 40psi. Just my 2c's
Car: 1983 G20 Chevy
Transmission: 4L60
WRONG... You CAN use the TBI ECM.. I have and it runs VERY well with NO code or hardware changes. I made changes entirely in the calibration. If you really want to do it right, you can upgrade the early TBI ECM with the EBL Flash with Port Fuel Mod from Dynamicefi.com. It is a great tuning system that plugs right into your stock harness.
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
