85 IROC will not start!!!
Old Sep 12, 2009 | 12:11 PM
mkralickz28's Avatar
Have an 85 IROC-Z 305 TPI just replaced the distributor, pick-up, coil, module, cap and rotor. All wiring is correct. Fuel pump works and has correct pressure at the shrader valve on the fuel rail. The cold Start Injector is working as the motor will start and run for about 2 seconds. The timing is set correct and is apparent when using the starter and timing light it shows at 4 degrees BTDC. Any Suggestions? Im thinking that the other injectors are not pulsing since once the cold start injector cuts out the engine quits. Fuses are good and the computer and engine were working prior to distributor replacement. Suggestions??? Thanx
Old Sep 13, 2009 | 01:17 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
Re: 85 IROC will not start!!!
Set the iac and tps correctly...........directions are in the technicl articles at the very beggining of the forum.........do that, and go from there..........check for vac leaks as well.
Old Sep 13, 2009 | 05:55 PM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
check and see if wires to oil senders are all on, the two wire plug runs fuel pump after startup.
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
Wade787b
Sep 29, 2015 01:15 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
mustangman65_79
Aug 11, 2015 03:17 PM
