92 TPI coughing sputtering after a few minutes
Old Sep 19, 2009 | 05:22 PM
KTMitch640's Avatar
Have a TPI on a Chevy 350 on my ****** truck build. TPI was on my other Jeep for a few years with no trouble. timing is right on, fuel press about 38- 40, filter clean. threw a code for Knock sensor, replaced it, now no codes. Starts easy, runs great for 5-6 min. then loads up coughs sputters but idles fine. If I let it sit for a while starts right up, runs great again and then same problem.. gettin ready to start throwin wrenches....
Old Sep 21, 2009 | 12:33 PM
KTMitch640's Avatar
Re: 92 TPI coughing sputtering after a few minutes
Any one have any ideas? Any tests I could perform ?
Old Sep 21, 2009 | 09:26 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
off hand? ignition control module heating up and causing miss fires? perhaps an injector heating up and dropping off? ohm your injectors cold then hot
bamaboy0323
Sep 3, 2015 06:07 AM
Bryan F
Aug 18, 2015 02:28 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
