LT1 TB on TPI intake
Old Sep 27, 2009 | 06:01 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
please just delete this and send me in the right direction through a pm if this is a repeated post, but i did a search and could not find an answer...
can i use an LT1 throttle body on my TPI? and is it an improvement or is the LT1 a 48mm TB also?... thanks for any help and i apologize if this is an inconvenience for anyone
Old Sep 27, 2009 | 06:18 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Re: LT1 TB on TPI intake
Stock TB on an LT1 is 48mm also...don't think you would gain anything from doing the swap. We usually go to a 52mm TB...bore out the stocker and what not as the 58 tends to be a bit much unless you have serious head/intake/exhaust work to flow that much.
Old Sep 28, 2009 | 04:02 AM
thanks so much thats exactly the info i was lookin for
Old Sep 28, 2009 | 09:38 PM
Pocket's Avatar
Car: 91 Trans Am
Also the LT1 throttle cam is completely different (still works)
The bottom vacuum port is missing on LTx TBs and the TPS/IAC connectors are the newer style
1992rs/ss
Jan 31, 2025 05:10 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
