Runs terrible when slightly warm dies when hot
Old Sep 28, 2009 | 12:57 PM
UK-1991-Z28's Avatar
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
Hey every one just after some advice of where to go next. 1991 Z28 350 tpi. When its cold it runs ok. Please forgive my explination if i get it wrong. When the choke/ cold start turns off she runs like a sack of sh*t impossible to drive, revs up and down no more than 1200 rpm at a peak and drops to a stall then it stalls and wont start then runs bad. until its stone cold again then its all good. Have done distribuator/ rota arm/ filters/ fuel filter/ plugs/ leads vacume hoses all the hoses i can see anyway. it seems to run lean as if its being flooded with air and starved of fuel but fuel pressur seems ok. Any help or advice or just say have you tried this your obvious might not be mine. many thanks guys.PS: its not throwing out any codes
Old Sep 28, 2009 | 01:04 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Runs terrible when slightly warm dies when hot
I wonder how your coolant temperature sensor looks. I would measure the resistance of it on a cold motor. There is a chart around here that show the proper resistance versus temperature.
Old Sep 28, 2009 | 01:14 PM
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
Is that the same as the engine temp gauge excuse me if it may be a stupid question
Old Sep 28, 2009 | 01:31 PM
Toehead's Avatar
It is not the same as the sensor for the gauge. It is right below the thermostat on the engine.
Old Sep 28, 2009 | 01:45 PM
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
ok i will take a look. if i disscconect it will it think its constantly cold? and therefore run with the choke still on ? im not great with electrical stuff. Many thanks
Old Sep 28, 2009 | 01:57 PM
Toehead's Avatar
There is no "choke" on a tpi car. The computer just compensates for the temperature. If the coolant temperature sensor is telling the car that it is a t a different temperature, it won't run properly. When mine went, it wouldnt idle hot.
Old Sep 28, 2009 | 02:01 PM
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
Ok thanks could that also stop it from driving aswell? This sound highly possible and im wondering if it could be the fact that its running a speceal heavy grade coolant?
Old Sep 28, 2009 | 02:13 PM
nomad350Z's Avatar
Car: 1988 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: WC-T5
Axle/Gears: 2.73:1 Open
my car has been doing the same exact thing. Turns out, it has bad fuel injectors, which is common for stock TPI systems.
Get your hands on an Ohm meter, and measure the resistance in each injector when cold and when hot. Before you start the car when its cold, unplug the injector wires and place a lead on each of the metal prongs on top of the injector. Measure and record each injector.
Repeat the process once the car has warmed up, preferably once its hot and stalling out. Let us know.
Old Sep 28, 2009 | 02:16 PM
Toehead's Avatar
A very good suggestion.
These old injectors have been having problems with the ethanol in modern fuel.
The injectors should have higher resistance than about 12ish when hot. They should also be fairly balanced.
Old Sep 29, 2009 | 12:37 PM
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
Hi, Just checked the injectots six are at 17.5 ohms and one at 4.3 and the last is 3.4 but this means nothing to me.
Old Sep 29, 2009 | 01:06 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
If I can remember correctly, that is too low and those two injectors need to be replaced.
Old Sep 29, 2009 | 01:27 PM
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
Do i have to remove everything down to the fuel rails to get them out?
Old Sep 29, 2009 | 02:01 PM
Toehead's Avatar
+1.
That is most likely your problem.
Old Sep 29, 2009 | 02:03 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Depending on which one it is yes. if it is injector 1 or 3, 6 or 8 i think you might be able to loosen the bolts that hold the rail to the lower manifold and then lift it enough to get the injector out of the bung and off the rail. the others are a little more tricky because they are hidden by the runners.
Old Sep 29, 2009 | 02:42 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
It would prolly be worth your while to replace them all as I seem to remember the later years injectors being problematic. Also remember to bleed off the fuel pressure, you should just beable to follow the instructions for changing a fuel filter. Don't need to get fuel in your eyes or all over your engine bay.
Old Sep 29, 2009 | 04:32 PM
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
Thanks guys tomorrow i will start pulling it down and let you know the outcome
Old Oct 18, 2009 | 11:33 AM
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: LSD
Well after waiting for the parts to come from Rockauto the Camaro is back on the road again and running sweet. It was worth the wait though as there nearly $200 each in the uk. Thanks for all the advice guys......
Old Oct 24, 2009 | 03:19 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
+1 to that, my 1991 T/A with the 305 TPI has been doing that. Bad injectors as well, probably because the car's been sitting for a year before I got it.
eightsixseven
Dec 16, 2024 01:50 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
