no oil pressure when stopped
Old Oct 4, 2009 | 02:59 PM
mmyers_417's Avatar
Car: 88 formula; 06 cobalt ss
Engine: 305 tpi; 2.4 ecotec
Transmission: WC T-5; F23
Axle/Gears: 3.45 posi; 3.84
Just bought a 305 tpi formula and i have around 20-30 when driving and 0 at a light when stopped and my ses light comes on and everything i am worried bc my work is 70 miles round trip and i wanna eventually make this my daily driver (already has alot of miles so idc) I read on here while searching sometimes they have negative crankcase pressure to let ring sit but idk if thats true any help will be appriciated thanks
mike
Old Oct 4, 2009 | 03:22 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: no oil pressure when stopped
it could be a simple oil pressure sending unit issue.
buy a cheap mechanical gauge, or replace the sensor.
problem persists, its going to be worn oil pump, cam bearings, or main bearings.
doesnt sound like it needs to be your DD at the current time.
Old Oct 4, 2009 | 05:32 PM
mmyers_417's Avatar
na i still got my dd as another car but i wanna check it with an oil pressure check (forget the name friend has it) but it might be my oil pump my oil pans pretty banged up so i guess it might have damaged the oil pump i wanna buy a new one anyway so if the problem persists then its the gauge
Old Oct 8, 2009 | 01:10 AM
petetinga's Avatar
Car: 05 P71 78 Monte 63 F100 88 S10 +3
Engine: 4.6L 383 461 310 & 355 305 2.5
Transmission: AOHE Sag Borg TH..
Axle/Gears: 308 325 op pos lok
cut your oil filter apart with tin snips and see if its full of bearing matireal
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
