tbi to tpi help please!!!!!!!
Old Oct 9, 2009 | 08:43 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Hi i am wanting to buy a 91 305tpi wiring harness and ecm and was wondering if i could put that to my 91 RS that i wanna convert to a 350 tpi. If i can what else would i need also would it have problems with the VATS.
Old Oct 9, 2009 | 09:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tbi to tpi help please!!!!!!!
Going to need a new tune for the 350 anyway ( unless you have a 91 350 memcal which will have VATS on it ) so get a custom chip with the VATS deleted along with other mods like fan on temps change
Old Oct 9, 2009 | 10:21 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
So it would come out kinda pricey doing all of this
Old Oct 10, 2009 | 01:51 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
$150 for a custom chip from PCM forless
Old Oct 10, 2009 | 11:17 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If you are serious about doing this, come by and I will clue you in as to what's involved. I have done several.
No charge....
Old Oct 10, 2009 | 12:16 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
The car is not in running condition since it hasn't get smogged yet, so is there any other way
Old Nov 10, 2009 | 09:25 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Dyno Don can you please pm me a quote for the swap i have the tpi system and all the sensors i need
Old Nov 11, 2009 | 07:31 AM
Karasawa's Avatar
Car: KITT
Axle/Gears: 2.73 one wheel wonder
Ive just completed a tbi305 to tpi350 conversion just a few months ago, its more time consuming then expensive if you plan on doing most of the work yourself. The wiring harness was biggest issue. A company "Howell Engine Developments, Inc" located in Michigan took my tbi harness in the rough shape that it was and rework it to new and converted it to tpi speed density. I paid somewhere around 300 for all the harness work and another 50 for the computer swap out, they gave me a comp that would work for my application. That alone made the whole conversion easier. Pretty much plug-n-play
Old Nov 11, 2009 | 12:32 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I did this swap as well.
You will need to replace the fuel pump for a high pressure one, also your exhaust is designed for a 305 and may be inadequate, the 350 uses larger diameter pipe and I think the exhaust manifolds are bigger as well.
Also the throttle cable and transmision kick-down cable will need to be changed, the tbi ones are too short.
Old Nov 11, 2009 | 01:25 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Was it worth doing the swap to tpi and have any of you guys have problems i am thinking of buying a harness from a 90 and its SD but not sure if it will work. Were can i find Howell Engine Developments, Inc to email him
Old Nov 12, 2009 | 04:26 PM
Yes the end product was worth it, but getting there was a major pita, and a money pit, at least in my case anyway.
If I knew then what I know now, I may have just put a 305 tbi back in it and driven it 'till it wouldn't go anymore.
Old Nov 12, 2009 | 04:36 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I was thinking of staying with the tbi and just putting a cam and porting my heads with the money i would spend to swap in a tpi what do you guys recommend me to do
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
