Sportsman 2 heads on 305?
Old Oct 20, 2009 | 10:27 PM
foxracer1's Avatar
Car: S10
Engine: 305TPI
Transmission: LS1 T56
Comments? I plan for mild boost. I got the heads cheap and got a lt1 cam gonna run 1.6 rockers. Peak lift of .480I .491Ex. Will i run in to cylinder wall clearence issues?
The heads will be milled 20 thou or so. Gonna use the compression drop for added room for boost. The 200cc runners are a little large.
Old Oct 20, 2009 | 10:34 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Sportsman 2 heads on 305?
You will run into cylinder wall clearance issues. The 2.02 valves hit the side of the cylinder wall at just over .500 lift bacause of the narrower bore of the 305.
There is an amazing thread with excellent pics on the site here, the pics taken from the bottom of the cylinder the guy posted all sorts of lift measurements vs valve size too.
Here it is!
https://www.thirdgen.org/forums/tech...ds-1-94-a.html
SOO sell the heads to me! haha
Last edited by 3rd gen Will; Oct 20, 2009 at 10:46 PM. Reason: Found thread I was talking about
Old Oct 21, 2009 | 07:55 PM
foxracer1's Avatar
Car: S10
Engine: 305TPI
ha ha well they are atop my 400 i'm building but thought about just running them on the 305 couldn't remember how much you could get away with on 305s.
Old Oct 21, 2009 | 11:46 PM
Right on man! But Hey I had to try! LOL
Old Oct 22, 2009 | 07:58 PM
foxracer1's Avatar
Car: S10
Engine: 305TPI
Its all good. It is worth a try. Thanks for the links.
Old Oct 22, 2009 | 11:34 PM
No sweat man, I am just glad there are guys on here like casey that do that kind of documentation so other people don't have to find out the hard way.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
