88 IROC 350 TPI buildup
Old Oct 21, 2009 | 09:32 PM
94Pontiac's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 350 Tuned-Port Injection
Transmission: 700 R4
Axle/Gears: 3:73
I got an 88 IROC with a tired 350 TPI...time for a rebuild. I plan on removing the engine and trans. 700R4 is gettin a rebuild and a shift kit. My questions lie in the 350 TPI. First off, I want to build up another 350, freshen up the block, bored, fresh crank, pistons etc. Could I take the TPI system and slap it on the other 350? From wat I understand, you need the heads (which are getting re-done). I dont want to butcher up the original numbers-matching block by boring it. And will i need to purchase higher end intake-runners, throttle body, etc to make up for the bore?Also, so I'm prepared, how hard is a 350 TPI removal and rebuild? Appreciate the replies, thanks TGO members.
Old Oct 22, 2009 | 12:00 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 88 IROC 350 TPI buildup
Boring the original block is the way to go and in no way lowers it value. You don't need to change the intake system (unless you want to).
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
