TPI 305 vs 350 Knock/ESC sensor/module question
Old Oct 24, 2009 | 08:12 AM
TPIMonteLS's Avatar
Transmission: Automatic!
I swapped from a 305 TPI setup to a 350 a few years ago but kept the 305 ESC module and the 305 knock sensor went into the 350 block, IIRC. I've read you should have the 350 sensors but if both are matched for a 305, how much would that affect performance on a 350? Are the 350 sensors a must? My 1/4 times have been very dissapointing and everything else on the car is checking out ok (fuel pressure, timing, etc), the only thing I can think of is if the sensors are affecting the timing, and/or the timing tables in the PROM not being ideal for the current setup.
Old Oct 26, 2009 | 06:03 PM
TPIMonteLS's Avatar
Re: TPI 305 vs 350 Knock/ESC sensor/module question
TTT
Anyone?
Old Oct 26, 2009 | 06:13 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
what are your times??
Old Oct 27, 2009 | 12:19 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Personally, I would change them. i did the same swap out. The major things to change out are the PROM, ESC module, Knock and Injectors. Everything else is interchangeable between 305 and 350.
Fast355
Dec 2, 2016 06:33 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
