wrong esc module
Old Oct 25, 2009 | 09:27 PM
mreld3r's Avatar
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
wrong esc module
I have a 350 in an old 305 car. 1986 tpi.
It still has the 305 ESC module in it. What problems will that cause. I have read that I need to change the esc module to a 350 one,,,why?
Am I getting un-necessary ignition retard? I "do" have a 350 knock sensor installed. Are they a matched set or what?
I never get any pre-ignition, even with 87 octane.
Am I losing a lot of performance/fuel mileage because of premature ignition retard?
I used the search; but only found people saying that you "have" to change it when you install a 350,,,,,but no one says "why".
My engine runs ok, but the gas mileage is poor. Also I have a 4.10 rear,,,,so it aint gonna be good anyway. If it is gonna help my mileage or improve performance a good bit, i'll change my ESC. Can anyone give me some advice?
I guess my main question is: Am I gonna get $85 worth of performance increase by changing my ESC??
Old Oct 25, 2009 | 10:31 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Re: wrong esc module
I beleive the ESC module is matched to the knock sensor, and with the 305er its probably picking up false knock. I think I remember reading somewhere that it can pull as much as 20* out. Which in turn will kill performance as well as milage. I would save your $85 and go hit the local salvage yards. The modules labeled with BLH is for 305's and the ones labeled with HKR are for the 350's.
Old Oct 26, 2009 | 05:54 PM
mreld3r's Avatar
Thank you, is this ESC a "tpi only" item or will other cars have them as well, because the local tpi boneyard cars are already stripped clean.
Old Oct 27, 2009 | 12:51 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
I beleive there are other cars that you can find them in. I dont remember what they were off hand but I am sure some searching here on TGO will yeild some good results.
Old Oct 27, 2009 | 07:20 PM
mreld3r's Avatar
great ***** o' fire!!!!
Just for the heck of it, i unplugged my knock sensor and holy-moly my car runs like a bat outta ,,,,, when I first unplugged it and cranked my car, I knew that something was up because it idled at 1500. And then when I put it in drive and took off,,,,it was super responsive and it RAN GREAT.
Old Oct 27, 2009 | 08:14 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
do you have a"gear"cam drive or anything else that
could be triggering the knock sensor?-if not,must just
be a bad(or wrong)knock sensor.I have heard flat tappet
and roller cam engines use different ESC modules
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
