Push rod help
Old Oct 26, 2009 | 06:40 PM
raidmagic's Avatar
Push rod help
we are putting a 383 in a buddies 85 but today while assembling the motor we have come to the conclusion that the push rods are too long. The ones in the motor now are 7.75" and when we adjust them the valves don't close. Can someone tell me what size pushrods we need?
The came is 440 lift on the Intake and 454 lift on the exhaust. It has 1.5 RR. Advertised duration is 270* intake and 276* exhaust. Flat tappet. The heads are summit castings and it has 1.5 full roller rockers also summit brand
Hopefully that is all the info needed. Any ideas?
Old Oct 26, 2009 | 06:51 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Push rod help
You can get a push rod measuring tool from Compcams, basically it is an adjustable pushrod you adjust to perfect length and then measure.
Old Oct 26, 2009 | 07:47 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Re: Push rod help
The engine being a stroker has no bearing on the push rod length. you should use stock rods for that set up. flat tapped, 1.5 ratio, this is all stock stuff.
you may need guide plates
might wanna recheck your installation procedures and make sure your hydraulic lifters are good and that you have the proper valve springs for your cam.
Old Oct 26, 2009 | 08:33 PM
raidmagic's Avatar
Re: Push rod help
Hmmmm I guess checking the valve springs is next. The pushrods are stock length. Thanks we'll do some more measuring.
Old Oct 26, 2009 | 08:43 PM
Damon's Avatar
Re: Push rod help
Aftermarket heads and/or cam always require a pushrod length check. They often move things around in subtle ways vs. stock.
7.80" is stock length for a small block Chevy with a flat tappet cam, BTW.
Old Oct 27, 2009 | 02:32 PM
raidmagic's Avatar
Re: Push rod help
Would it matter if we did this with the engine on a
stand with no oil in it? Would the lifters not being pumped up matter?
Old Oct 27, 2009 | 02:44 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Re: Push rod help
No, many people have built motors on stands including myself. The only thing is that the lifters need to be primed with oil (soak in oil overnight before installing)
Now if I am correct, when you put the pushrod in and place the rocker on the stud, you are tightening the stud bolt all the way down, so that the valve is open and never closes?
If so that is not the right way to do it. The proper way to do a valve lash is to make sure that the cylinder is on the compression stroke and bring the piston TDC. Once it is there, place the rocker on the stud and slowly tighten the nut while spinning the pushrod with your thumb and index finger. Once you feel a slight resistance/drag stop. At that point tighten the nut 1/2 turn. that should give you zero lash. Now, at the same time, if you let that sit for a while the pushrod will feel like there is no resistance again. Don't worry, this is becuase the pressure of the valve spring is forcing the lifter to become preloaded. Once the oil pressue raises it will be good. If you are not sure, take the rocker off and do it all again.
The easiest way is to do the firing order of the motor, and do both intake and exhaust at the same time for each cylinder.
Old Oct 27, 2009 | 03:32 PM
raidmagic's Avatar
Re: Push rod help
Below is the procedure we used to set the valves, the lifters were not soaked in anything and put in the motor dry.
Rotate the engine until the mark on the timing tab by the damper lines up with the ZERO position in the number one firing order. You will want to pull the #1 spark plug (driver side front) with your finger in it while turning. When it pushes out air hard as the line comes to ZERO - you are there.
In this position - you can adjust
Exhaust - 1, 3, 4, 8
Intake - 1, 2, 5, 7
You will want to run the nut on the rocker down while spinning the push rod in your fingers. When you can't easily spin it - are at zero lash. From there go one full turn.
Now, rotate the engine one full revloltion
Exhaust 2, 5, 6, 7
Intake 3, 4, 6, 8
Repeat...
Old Oct 27, 2009 | 03:58 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Push rod help
Yes that is also the correct way of doing it. It saves time as you do not have to rotate the motor. Now the trick with this one as well is that the motor has to be with the number 1 piston TDC on the compression stroke and not the exhaust stroke. The easiest way to find that is if you have the timing cover off, line the two dots on the gears up. when that is done adjust these valves
Intake - 1, 2, 5, 7
Once those are done, spin the crank 360* and then adjust these valves
Exhaust 2, 5, 6, 7
Intake 3, 4, 6, 8
like I said to adjust them do what I said. Spin the pushrod until there is a resistance and then 1/2 turn on the nut. make sure that the socket is not pushing the rocker down as well as it will give a false reading when spinning the pushrod.
If the cover is on the motor, then you can tell as soon as you try to tighten the number 1 exhaust valve, it will tighten sooner than the intake and will look like it wants to open the valve. If that is the case adjust the second set if rockers first, or turn the crank 360*
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
