Dead Cold Start Injector?
Old Nov 2, 2009 | 07:10 PM
Stephen's Avatar
Car: 87 GTA
I have the 9th injector on my 87 GTA, and it has always fired up within 1 second of turning the key, then dropped to a steady idle.
Lately, it has fired off, stumbled and died, on a cold engine. Unless I blip the throttle.
It seems as if the cold start injector isn't doing its start job, as the only time it does that, is on cold starts. Once it has run, if I kill it & try to restart? It'll fire right off & drop to a smooth idle.
Could the cold start injector have gone bad somehow? Clogged? Dead signal? Fried?
Old Nov 2, 2009 | 07:51 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Dead Cold Start Injector?
Possibly, it's a fuel injector just like the other 8. I'd try ohming it first, that might tell you if something's gone wrong with the coil in it.
Old Nov 3, 2009 | 04:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
FYI - the cold start injector should be 4 ohms.
Old Nov 3, 2009 | 01:32 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
check the thermo switch that controls the ninth injector
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
