MISFIRE
Old Nov 3, 2009 | 05:31 PM
joe2844's Avatar
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
MISFIRE
ok so i put my stock valve covers back on due to the Mr. Gasket ones being leaky pieces of garbage. now i have a misfire at idle, and hesitation when i hit the throttle off idle. its an 88 tpi MAF from an 88 iroc camaro, motor ran 100% prior to swapping valve covers out. so i checked my pcv valves and noticed that on the drivers side port where the hose hooks up on the manifold is pushing air, not pulling vacuum. is this normal? what did i do?
Old Nov 3, 2009 | 05:49 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
Re: MISFIRE
sounds like a vacuum leak or false air. something you did while swapping covers caused the problem. get a can of carb cleaner and judiciously spray it around the suspect vacuum lines and intake ducting. revs will pick up when you find it. berryman b-12 is a good choice for carb spray.
db057
Jan 10, 2020 08:55 PM
NZKnight
Oct 15, 2015 02:47 PM
camarohelp
Sep 22, 2015 03:19 PM
Jk_Under
Sep 8, 2015 08:13 AM
Thaney9
Aug 29, 2015 03:16 PM
