Injectors Question
Injectors Question
hey guys i have a 91 z28 5.0 5 speed that might need injectors. the idle is rough all the time and i have already changed the o2 sensor, tps, IAC valve, coolant temp. sensor, map sensor and checked all the vacuum lines and still no luck with fixing the rough idle. i'm hearing it is likely i need injectors considering they look all original. it does have a hypertech thermomaster chip in it, but other then that the engine is a reman. that is stock other then underdrive pulleys and a cooler fan switch. which injectors are good to use on that set up, Accel, Bosch, 19lb, 23lb?
thanx
thanx
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: Injectors Question
Everyone seems to like Bosch III's and you need 19lbs, how about testing your injectors with an ohm meter first
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Ohm'ing them out first is a good idea. Also you can take a long screwdriver, put the tip on an injector and the other end on your ear. You can hear them fire. See if they all sound the same.
If they look good, take a timing light and put it on each plug wire one at a time. See if it flashes evenly on every cylinder at idle. If not, it's probably a bad pickup coil in the distributor (assuming your plugs and wires are good). I've seen them cause lots of flaky idle problems.
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
i'll give you good advice,a tip and a shortcut all in one word: FIC !
http://www.fuelinjectorconnection.com is the way to go !!!
Grab your phone and call FIC !!!!!!!
FIC Is the way to go !
Jon at FIC won't steer you wrong !!!!
He has a huge following at Corvetteforum.com
Here's the contact info :
Fuel Injector Connection, LLC
4966 Wade Valley Way
Cumming, GA 30040
Tel: 770-888-1662
Jon at FIC http://fuelinjectorconnection.com/shop/
Had the luck of purchase from FIC,you won't go wrong with them
Jon will assist you and guide you,he even called me (im overseas)
to resolve all of my installation issues and guide me thru all the process !!!
I recommeded him with my TPI friends that went to Bosch III's and i swear we have never looked back or choose another provider !!!
now i got a set of Blue pearl ZR1 style injectors for my L98 !!!!
I stand by my words and FIC is the right choice !!!
check this out :
You won't be dissapointed,just do research or jump and call FIC and you'll know what im talking about !
Cumming, GA 30040
Tel: 770-888-1662
check this out :
thanx
thanx
info@southbayfuelinjectors.com
516-492-6504
www.southbayfuelinjectors.com
Ok I will ohm test them and see what they sound like as well. They are supposed to be between 13 and 16 right? If I end up needing injectors ill def call FIC and deal with them. and also if its a bad pick up coil then the cylinders wont all fire evenly? and the car does have new plugs wires cap and rotor.
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
The most important thing you are looking for is that they are all within the same spec as each other (and between 13-16, depending on temp). TPI is a batch fire system, meaning the ecm fires on entire bank of injectors at the same time, so your 4 right bank injectors fire at once and the 4 left bank ones fire at once. If one injector on one bank has a less resistence than the other 3, it will run richer than the other 3 and cause the other 3 to run leaner since electricity takes the path of least resistence. If the batch with the bad injector is on the drivers side bank with the o2 sensor, it could even be causing the other bank to run less than optimal since the ecm will be seeing a different a/f ratio than what the passenger bank is putting out due to the bad injector on the drivers side bank.
Also keep in mind that a 1991 car has the bad fuel injectors. There were 2 different brands used in the entire run of tpi cars, one type from 85-88, another from 89-92. The later ones are regarded as much cheaper and likely to fail.
Id say new injectors is $200 well spent on your car even if none of them are terribly bad right now.
