Fixed broken valve spring, now no power??
Old Nov 6, 2009 | 10:26 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Alright folks,
Last time i posted on here my car had just broken an intake valve spring on cylinder #2.
https://www.thirdgen.org/forums/tech...pring-why.html
The final diagnosis from the shop was that the spring had broke, and that the stud in the head had lifted out.. He said there was something with the pushrod but i cant remember.. They did a test where they put air into the cylinder and the cylinder held the air in, valve still good i guess??
Anyways.. Tonight was the first night that I have been able to drive it since it was fixed, and I now notice that there is a severe lack of power compared to what it had right before I broke the spring.
The motor is acting like it's sick and has a really bad miss, I can FEEL the motor shuddering when I give it throttle, and the car is acting like it wants to bog down while in reverse. The car isn't as loud and mean sounding as before, the car doesn't rev up as fast anymore, and there sure as hell isn't as much pep like there once was..
This is exactly how the car acted right before I pulled the valve cover and noticed the broken spring.
I put in BRAND NEW spark plugs not 200 miles ago and i'm at a total loss as to why my motor is acting like crap.
Does anyone have any suggestions?
Old Nov 7, 2009 | 01:58 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
Re: Fixed broken valve spring, now no power??
Hmm could be alot of things. Did the shop rebuild the head with the bad stud? Did the shop tighten the rocker arms the right way? Did the shop replace the lifter and push rod on cylinder #2? Is the engine in the right timing meaning are the spark plug wires in the right place? I would start with the easy things before I start tearing into the motor to find out.
Old Nov 7, 2009 | 02:04 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i would run a compression test. you could have had more than 1 broken spring
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
