Check engine light on Engine Stumbling
Old Nov 10, 2009 | 09:24 AM
aharvel50's Avatar
Hey guys I need some help im no where near new o camaros but I am to fuel injection. I have a 1991 z28 w/ a 305 TPI, The check engine light has recently come on and the computer is spitting a code 44. The car will run and idle if you listen closely you canr hear the "misfire" in the exhaust and the car will stumble not much but slightly at partial throttle. the car runs like a champ though whenever you stomp it. The injectors and o2 sensors have been replaced. The code from what I can tell can indicate low fuel pressure, bad o2 sensors, bad, map sensor, or a bad ECM. oh also the car has no trouble starting. Any and all help would be appreciated because im at a loss. Thanks
Old Nov 11, 2009 | 07:39 AM
Karasawa's Avatar
Car: KITT
Axle/Gears: 2.73 one wheel wonder
Re: Check engine light on Engine Stumbling
sounds like a compromised plug wire, check your wires, at night with no light open the hood with it running, you'll see it if there is a bad wire. The engine light could be triggered by the o2 sensor throwing a fit because the misfire. could even be timing slightly off, just a hunch
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
