TPI 5.7 wont run
Old Nov 10, 2009 | 07:05 PM
Karasawa's Avatar
Car: KITT
Axle/Gears: 2.73 one wheel wonder
TPI 5.7 wont run
1992 Firebird, 305 tbi to 350 tpi conversion.... the fuel pump is new and this car ran, parked it to repair a water/oil mix issue with intake manifold gasket. It only sat for about 3 weeks, took fuel line loose at filter, pump will jet fuel through filter. 9th Injector is blocked off and ignition is working, double checked timing. The fuel rail doesnt seem to be holding pressure so it will not start. Is there a check valve or something im over looking? Like its bypassing, I dont smell fuel as if it were flooding, Ive checked fuel lines up to rail to make sure there isnt a cripped line. The rail is getting fuel ... im out of ideas .. could the rail be at fault and why?
Just replaced fuel regulator to elimate that as a suspect
Old Nov 18, 2009 | 08:40 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Re: TPI 5.7 wont run
Do you have fuel in there?
Old Nov 18, 2009 | 11:44 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Are both plugs on the back of the distributor fully seated?
Does it crank and crank and nothing, or does it cough and sputter and still not start?
What did you use as a coupling for the new fuel pump?
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
