Fuel Rail o-ring kit help !
Old Nov 14, 2009 | 12:50 PM
hzemall's Avatar
I am building up my TPI system and I took at apart sometime ago to get things painted, polished etc etc. I am now putting it back together, BUT I can't remember which o-ring goes where.
I know the 4 same ones are for the front tube that goes straight across but I can't remember where the other 4 go on the back tubes and regulator AND what the large one is.
Can someone help out with this? I can't even find a diagram or anything.
Old Nov 14, 2009 | 03:10 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Fuel Rail o-ring kit help !
the large one is for the cold start valve if you have a 85-88 and the other is for the line feeding the cold start.. the other two small ones are for the inlet fittings. but usually are wrong.. the other 4 same ones are for the crossover tubes
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
