Code 15 and 21 can't fix.
Old Nov 28, 2009 | 10:17 AM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Code 15 and 21 are coming up. I have replaced the CTS, ECM, and TPS(about two years ago but the 21 has been on for that long anyways). but the codes are still coming up. The car stutters when i give it a lot of gas. What else can i check? Thanks.
Old Nov 28, 2009 | 11:29 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Code 15 and 21 can't fix.
I did a little research. From what I find both circuits use a black wire #452 going to the ECM pin D2. You possibly have a bad ground to the ECM, bad connection or bad/broken #452 wire. Hope that helps.
Old Nov 28, 2009 | 01:19 PM
trueburton's Avatar
I also seen that they share a ground. So i checked continuity and it seems to be fine. Still confused...
Old Nov 28, 2009 | 01:33 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
It's worth removing, cleaning, and tightening the grounds on the back of the passenger side head. That's where everything gets a reference from.
Old Nov 28, 2009 | 03:05 PM
trueburton's Avatar
thanks for the reminder. This is what I found. Probably a good place to start. haha
Old Nov 28, 2009 | 03:55 PM
trueburton's Avatar
well i bolted the grounds back on and reset the codes. Started the car and ran it for 5 mins. code 15 came back right when i started it but 21 never came back. any other ideas? thanks
Old Nov 28, 2009 | 04:42 PM
jv9999's Avatar
Engine: 5.7L/350
Have you measured the CTS? It should be between 180 and 450 ohms at running temp (disconnected of course). The terminals from the ECM should be ground on one side and +5 on the other (also disconnected).
Old Nov 28, 2009 | 06:09 PM
trueburton's Avatar
not sure about the ohms but the sensor is brand new. I checked the connector and it is at 5V. with ground.
Old Nov 28, 2009 | 08:36 PM
jv9999's Avatar
Engine: 5.7L/350
It could just be a bad one. What are you reading the voltage with? Most meters can measure resistance. If yours can't, borrow one.
Old Nov 29, 2009 | 09:34 AM
trueburton's Avatar
how exactly do you check resistance?
Old Nov 29, 2009 | 10:27 AM
jv9999's Avatar
Engine: 5.7L/350
This is a good tutorial (scroll down a bit): http://www.ladyada.net/library/metertut/resistance.html
Old Dec 3, 2009 | 04:58 PM
trueburton's Avatar
With the ECM unplugged, should the D2 pin be grounded or does it recieve it's ground through the ECM?
Old Dec 3, 2009 | 05:08 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I beleive it is grounded thru the ecm.
Old Dec 3, 2009 | 05:11 PM
trueburton's Avatar
yes it is thanks. Still not sure why the codes are coming up though.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
