Tpi Mpg Question
Car: 1989 Chevrolet Camaro iroc-z
Engine: 350 Tpi
Transmission: t5 Tranny
Axle/Gears: 3.08
Tpi Mpg Question
I know that you are supposed to use Premium in these cars, but ive been using Unleaded. My question is, Since im using unleaded, is my timing being retarded? Causing a loss of power and a drop in mpg?
Thanks!
Thanks!
Re: Tpi Mpg Question
All gasoline today is unleaded so I assume you mean you are using 87 octane. Higher octanes burn more slowly so by running 87 octane instead of 93 you are actually advancing the timing slightly.
Engine: 350 Tpi
Axle/Gears: 3.08
yeah but since its burning quicker, wont the knock sensor catch something and retard the timing?
Car: 87 GTA
Higher octane over what an engine needs, only benefits the retailers wallet.
I aways run 87 & track my mpg. I actually tried 91/93....whatever octane the highest Super Unleaded was, for several months. Even disconnected the battery to resey the PCM so it could "learn" & re-tune for the higher octane. Made zero diferrence to my mpg, so I went back to 87. My wallet is much happier now!
Car: 1989 IROC-Z
Transmission: Th700R4
Over in sweden is 95 octane the lowest one you can get.
We have 95 and 98...
Im using 95 cause its little little cheaper.
But it still costs $6,5 / gallon (95 octane) or 12 SEK / liter or $1.71/liter [litre]
we have ~70% taxes on the gasoline, thats why its so ****ing expensive....
Someone care to ship some gallons to me ?
Engine: 350 Tpi
Axle/Gears: 3.08
im almost positive you have to run premium in these cars, or else you will ruin your catalytic converter
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
The main things that will ruin a catalytic converter is leaded fuel or an extremely rich/lean condition and burning oil. Fuel octane rating will have no effect on the cat.
Car: 87 GTA
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
We actually saw a fair number of these cars that the premium gas available there (ann arbor michigan) would eat the injector windings, and lead to shorted injectors, and cars that ran like crap. We would do at least two a month. I don't know what insane blend the yuppies in ann arbor wanted in their gas, but, it just wasn't friendly to the GM injectors.
Car: 1989 Firebird Formula 350 TPI
Engine: 5.7 350 TPI
Ok I have always been under the impression that 93 is just better for you car no matter what. I have always used 93 in my formula 350. Never tried anything lower. What are the differences between the grades as far as the car is concerned. Like will diferent grades make the car run better or prolong its life, etc? I have tow repair manuals (Chiltons and Haynes) and Im certain they both show 93 as the recommended gas. I remember when I drove my 87 with the 305 carb it ran like crap on 87. Sometimes the carb would flood itself. That car was stock. Anyways just thought it would help if someone who knew their stuff regarding this matter would outline for people running stock set ups the differences and the plus and minus' of running our car with each respective grade.
PON (pump octane number) = ( RON (research octane number) + MON (motor octane number) )/2
As for the gas prices...The Netherlands has the higherst gas prices in the world unlike what some claim not to be true but it is, a litre costs $2.10 and a gallon costs $8
It's been as high as around 10$ a gallon here back when a barrel was 175 dollars or whatever it was at it's highest. Last edited by Twin_Turbo; Dec 16, 2009 at 05:44 AM.
Our engines aren't exactly high compression, and they are naturally aspirated. There isn't any reason that 87 octane gas should cause a problem. If you're 'feeling' a difference on a LG4 with 93 octane, it's just a placebo effect. Even the higher output cars only had 9.3:1 compression. These aren't Ferraris, we're safe on cheap gas. Unless the engine pings under load on 87, don't worry about it.
http://www.cartalk.com/content/featu...questions.html
Sanjay
Aug 12, 2015 03:41 PM
