TPI Computer Questions! Please Help I want to make the right decision
Old Dec 13, 2009 | 07:42 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
ok, i will be buying a TPI setup from a 1989 Trans am GTA and putting it on my 305 Camaro. It comes with everything except for fuel rails,injectors,PROM,and distributor.So, which chip do I need. Could I put a chip from a 350 in the computer with the right size injectors on a 305 or will i run into a problem. Will i need the chip from a 305 to make it right. Im asking because I believe i will run into a VATS issue and oddly summit has a chip with VATS delete for a 350 but not a 305. Could someone please help I'd like to do it right. I dont want to get any custom tuned chips
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
