oil pressure switch location 305 tpi
Old Dec 26, 2009 | 09:30 PM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
on my 85 t/a where is the oil pressure switch located? i need to replace it because of a leak and drop in pressure.
thanks
Old Dec 26, 2009 | 10:27 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: oil pressure switch location 305 tpi
Back of the block, down by the base of the distributor.
PS, please fill out your vehicle information in your profile.
Old Dec 27, 2009 | 08:28 AM
thetaman85's Avatar
what would be the best way to access it? (from below or above) and how much of a mess will i make doing it?
Old Dec 27, 2009 | 08:57 AM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
on a 85 there are 2 switches 1 for oil preasure 1 for fuel pump relay, the single wire one is for preasure get at it from the top.
Old Dec 27, 2009 | 10:14 AM
burnout88's Avatar
Car: 88 IROC
You can usually only get it from the top.
See links
http://ww2.justanswer.com/uploads/mo...141753_oil.png
https://www.thirdgen.org/forums/tech...ding-unit.html
Old Jul 25, 2013 | 09:37 AM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
Transmission: 5-speed
I have a 92 RS, if the oil pressure switch was going bad, I would see little or no oil pressure, correct? My oil pressure is always really high, usually around 45-60 psi, so I'm taking a guess that my oil pressure switch is working well?
Old Dec 13, 2016 | 02:00 AM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
db057
Aug 22, 2015 08:17 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
