iroc l98 HSR and cam choice
hi, i have a 89 iroc 350 tpi and i want put a HSR found this but i don't know what i need to put them on my car, my car have march UD pulleys, hooker shorty headers, custom 3" y-pipe, and a mild work on heads, i want my car in around the 350 rwhp but this is a good start? and what i need ?? thanks...
http://www.summitracing.com/parts/WND-7540/
i know that i need the fuel rails but what else thats everything?? i read a lot but i can't find anything...
Re: iroc l98 HSR
Read the stickies in the "Alternative Port EFI" forum.
This is one of them that will answer a lot of your questions:
https://www.thirdgen.org/forums/alte...nversions.html
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: iroc l98 HSR
ok thanks, i understand that the HSR is not for me, but the only thing is first i need a camshaft, for a good hp but daily drive, what did you think? zz9 or zz4 or lt4 ...... the slp runners is waste of money?? and port plenum and tpis base?? i just don'd have a lot of money since i'm a student so what i need to know?? regards....!!!
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
Re: iroc l98 HSR
Well my brothers firebird (now mine) had the SLP runners, Edelbrock base, ported stock pluneum, 52 mm throttle body, and 1 5/8 slp headers, hypertech chip, a comp cam with a duration 210 / 218 at 50, and ported stock heads. With that combo the car would do a 14.4 and the car was very good for daily driving. Just thought I'd mention once he changed the heads to some Trick Flows the car got into the 13's
The the pluneum was port by hand via a Dremal that part isn't high tolerance so you can save some money doing that if you buy some new runners. Another thing that will cost you nothing but improves air flow into the engine is to remove the screens on the MAF (just be sure never to run the car without an air filter on if you do that) The old HOT ROD magazines I have talk a lot about stock throttle body and air cleaner box are very restrictive, those are inexpensive to change or modify so doing something with that too would probably be a good idea.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: iroc l98 HSR
HSR on a good L98 and alittle bit of tuning will do 250-260whp and run bottom 13's with gear/converter/drag radials in good air. Thats a peppy daily driver.
mustangman65_79
Aug 11, 2015 03:17 PM
