TPI SNORKEL WONT FIT 91 BIRD
Old Jan 25, 2010 | 11:01 AM
Pyronight's Avatar
Car: 91 firebird/68 Camaro
Engine: 3.1L V6/Ram jet 350 crate
Transmission: T-5/L60E
Axle/Gears: 7.5 10 Bolt/3.90 posi
I am trying to make a dual snorkel system off an 87 bird fit my 91 bird and I cant get it to fit. My hood REFUSES to close. PLEASE help me figure a way around this issue.
Old Jan 25, 2010 | 11:23 AM
Jeffs82TA's Avatar
Re: TPI SNORKEL WONT FIT 91 BIRD
put a camaro front end on the car, that will fix the problem.
Old Jan 25, 2010 | 11:51 AM
Guest
Guest
Posts: n/a
Yea, what he's trying to say is that is not a Firebird part, that is off a Camaro and no it will not fit.
Old Jan 25, 2010 | 09:34 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Old Jan 26, 2010 | 02:36 AM
Pyronight's Avatar
But thats what I dont understand. I pulled it off a FIREBIRD not a CAMARO. I thought the same thing until I looked at the car. it was a bird. Kinda looked like they had cut the thin sheet metal near the hood latch and dropped it in there.
Old Jan 26, 2010 | 06:41 AM
Jeffs82TA's Avatar
Use a Pontiac adjustment tool to make it fit properly. "hammer"
Old Jan 26, 2010 | 07:20 AM
Twin_Turbo's Avatar
Why go through all the trouble to mount that restrictive thing?
Old Jan 26, 2010 | 10:16 AM
Pyronight's Avatar
What would you suggest then? The current air box is inside the engine compartment sucking up all the hot air.
Old Jan 26, 2010 | 10:53 AM
Damon's Avatar
On a 3.1L V6 you think a little warm underhood air is the only reason your car doesn't go fast?
Firebirds/Trans Ams never had that intake system on them from the factory. The hoodline on a FB/TA is too low in the front to leave enough room above the radiator support for it. Somebody made it fit before you swiped it off.
The factory intake from a 91/92 V6 is plenty good, with minor modification. Pop the rivets that hold the plastic intake "nose" on the filter housing can and the hole underneath it is plenty big, and easy to attach a cold air hose onto, if you want. Then run it forward or down to pick up colder outside air. K&N makes a filter that fits it as well.
If you look at that plastic "nose" on the factory filter housing you'll see it's necked down so small you could barely drop a quarter through it. And when I pulled it off, I found out why- it acts as an intake silencer. Noticably more intake howl with it removed. But clearly it would be easier for the air to get into the filter housing with it removed.
Old Jan 26, 2010 | 10:55 AM
Jeffs82TA's Avatar
I would think the stock V-6 air intake system would be sufficient for a 6 banger and it gets cool air just as well as in front of the radiator. Besides doubt that V-6 will benefit any from all the work.
theurge
Aug 21, 2015 12:46 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
