Weiand Stealth Ram Vortec Intake Manifold
Old Jan 26, 2010 | 05:53 AM
t-topsavage's Avatar
Car: 1988 Camaro IROC-Z/28
Engine: L98 5.7L T.P.I, stroked 383
Transmission: turbo hydro-matic 700R4
Axle/Gears: Borg Warner 9 boltG80 2.77
Hey I have an 88 Iroc with the L98 that I stroked to a 383 cid stroker. its still got stock heads, stock cam and stock T.P.I intake on it. I really want to use the Weiand Stealth Ram Vortec intake manifold just cause I like it and its gonna do exactly what i want, I just dont know what heads to use with it and what injector size I should go with, or camshaft to... I dont think the zz4 cause it wont be big enough for the 383 but maybe the zz9? and then I need a small cap distributor so what should I get for that? im lookin for a mean street machine to cap out at around 450hp and ill be happy. and a torque convertor for a Hydra-Matic 700-R4 4 speed automatic? and flywheel to while im at it... long list I need opinion and help sortin through some ****.. much appreciated..
http://www.holley.com/7542P.asp
~Peace
Old Jan 26, 2010 | 06:35 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Weiand Stealth Ram Vortec Intake Manifold
$280 Cheaper here
http://www.summitracing.com/parts/WND-7540/
http://www.summitracing.com/parts/HLY-534-185/
You only need the Vortec version if you are buying Vortec heads
Any small cap dist from a F-Body or '87- '93 TBI truck will work
Pick cam after you have picked heads
Old Jan 26, 2010 | 07:26 AM
thanks man cheaper is always better haha. These heads look pretty legit to me.
http://www.jegs.com/p/GM-Performance...49898/10002/-1
Old Jan 26, 2010 | 04:55 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Most run 195's on a street 383's
http://www.summitracing.com/parts/TFS-30400001/
Old Jan 27, 2010 | 01:33 AM
hey is the L98 considered a first gen chevy small block?
Old Jan 27, 2010 | 06:20 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Yup
LT1 is Gen II on account of the reverse coolant flow block and heads but still uses Gen I parts inside block
LSX are Gen III .Nothing fits earlier engines
Old Jan 28, 2010 | 01:43 AM
ok thanks alot thats good to know something ive been trying to figure out..
9192camaro
16
Feb 3, 2019 12:21 AM
earlpote
Aug 28, 2015 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
