Engine Wiring Harness Differences (?)
Old Jan 29, 2010 | 03:39 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
I'm currently trying to find an Engine Wiring Harness For a 91-92 5.0L TPI 5-speed manual (Speed Density of course) and I was wondering what the difference is between a harness from a 5.0L TPI AUTO and a 5.0L Manual is? Can a harness from an Auto work with a Manual car? or modified to work? GM part #'s are different between the two so there must be difference...
thanks in advance
Old Jan 31, 2010 | 01:56 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Engine Wiring Harness Differences (?)
The auto harness will have a plug for the torque converter lockup, the manual one will not. Also, I think the manual harness has an extra plug or two for the reverse gear switch, and fifth gear switch. I'm sure the harness could be modified to work though.
Old Jan 31, 2010 | 04:08 PM
Drew's Avatar
I've got both out in the garage on the shelf. The only notable difference between the auto and 5spd harness is the transmission plugs. The 700R4 harness has the 4 pin plug, and the T5 harness only has a 2pin for the reverse lights. Otherwise the two harnesses are identical.
Old Feb 1, 2010 | 09:22 AM
thanks for the replies, thats the difference i came up with as well this weekend with some non-TGO research. So at least we know now that an auto harness can be used when swapping to tune-port with a manual tranny.
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
