Annoying 350 TPI
Old Feb 4, 2010 | 05:38 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Annoying 350 TPI
I cant get this engine to idle smoothly, ever since I changed from 305 to 350 with the same TPI setup.
The sensors required have been changed and cannot seem to get a smooth idle no matter what I try, with no codes.
I noticed my fuel pressure isnt bang on every time I start the car, today for example it was idling at 30-35 psi, where most it would be 35-38 psi at idle.
The fuel pump is new all my sensors are a year old.
Any ideas?
Old Feb 5, 2010 | 04:56 AM
MrBill85T/A's Avatar
Car: 85 T/A
Transmission: 700R
Re: Annoying 350 TPI
Which injectors did you use? did you follow this outline? The 305 19lbs are too small plus the prom in the ecu needs to be replaced with a 350 prom
http://tpiparts.net/305_tpi_to_350_tpi_conversion
Old Feb 5, 2010 | 10:42 AM
transamice's Avatar
Car: 87 GTA t-top
ECM + prom for 350, injectors are new 21s, knock sensor, spark advance changed, everything needed is changed.
Fuel filter and pump are changed, IAC TPS is new, Distributor is new, even bought another harness and ecm+prom to make sure thats not the problem.
It drives fine, no issues but just the idle is never smooth and the engine shakes.
Old Feb 5, 2010 | 12:17 PM
Car: 85 T/A
Transmission: 700R
Have you taken a vacuum reading? It may not be the computer control system. It could be a bad wire, plug, stuck injector or even a valve too tight. What is the condition of the 350? is it a new build?
Old Feb 5, 2010 | 01:50 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
I can be tricky sometimes getting the TPS set just right. It took a good couple of weeks making small adjustments on my TPI 383 to get it just right.
Old Feb 5, 2010 | 04:03 PM
transamice's Avatar
Car: 87 GTA t-top
Its a rebuild from last year, checked for leaks, everything is solid.Vacuum leaks were the first thing I checked for.
Could the fuel relay cause anything like this?
Old Feb 5, 2010 | 04:59 PM
Car: 1992 Camaro RS
Transmission: WC T5
If the fuel supply system was intermittant you would notice it in the fuel pressure.
If you can try to get a good scan tool and look at what the sensors are saying to the ecm.
Look for TPS or CTS irregularities.
Have you set the minimum airflow on the engine since you put the TPI on the 350? It is going to be different on a 350 than a 305.
Old Feb 5, 2010 | 07:04 PM
transamice's Avatar
Car: 87 GTA t-top
I need to borrow my mechsnics scan tool again, but Im using the rubber elbow from an 88 GTA and from the MAF to filter my own custom cold air.
My next diagnosis is using parts from a stock working 89 GTA and trying the TB and computer with my prom.
Old Feb 5, 2010 | 08:44 PM
thegooseman's Avatar
Car: 1992 RS
Maybe you need to adjust the IAC valve. Theirs a how to in the tech articles.
Old Feb 6, 2010 | 05:09 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Follow this link. Tells you exactly what needs to be changed. https://www.thirdgen.org/forums/tpi/...-swap-ecm.html
I had the same problem too. I fixed the problem when I noticed some white chalk looking marks on the exaust manifold. Upon further inspection, I realized that the spark plug wire was arching onto the header. So I hung the spark plug wire on top of the smog tubes and my idle went smooth agian. Make sure that your wires arent crossed. May be arching. Good luck bro.
Old Feb 6, 2010 | 06:28 PM
transamice's Avatar
Car: 87 GTA t-top
Ouch, thats brutal.
I have been though a few wires from burning on the headers so I got looms and boots, thats not the problem but still thank you.
The basics are really vacuum leaks and if you wires are burnt and I wish it was something obvious to detect.
A buddy of mine is a mechanic says the car is cursed and I shouldve stuck with a 305, I dont like that comment.
Old Feb 6, 2010 | 07:22 PM
Boper39's Avatar
Any ideas?
Try unplugging the timing connector, to put the ECM in base mode, of course check the timing, use spray choke cleaner to quick check vacumn leaks and pinch off vacumn lines. Also you can disconnect 1 plug wire at a time and see if you lose the same rpm from each, or unplug 1 injector at a time. You need to qualify the basic engine. Also the EGR could be leaking internially hard to get to but possibly take a extension or long rod and tap on it. Hope this helps GG
Old Feb 6, 2010 | 09:38 PM
Another issue could be with either the Ignition COntrol Module or the pick up coil inside the distributer.
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
