Fan relay and wire help
Old Feb 7, 2010 | 05:34 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hi guys. I know this is the wrong board but I was hoping that someone can tell me the type of relay and what the cut wires are use for (one of them is for the fan relay but how is it wired)? PO jerry rigged the heck out of this one. The fan stopped working. So I followed the wires from the fan and it lead to this junk circled in white. I took off the black tape and found what your seeing. Any help would be great. Also if anyone can provide pictures of they're actual relay, would be very much appreciated. The correct board is here..... https://www.thirdgen.org/forums/elec...ml#post4427948
Old Feb 7, 2010 | 07:18 PM
Jeffs82TA's Avatar
Re: Fan relay and wire help
The fan relay
would have been mounted up by the brake booster originally wouldn't it have? The relay should have had a green/white - orange - red - black/red - black set of wires going to it
green/white - ground from fan temp switch
orange - battery feed
red - ignition
black/red fan motor
black fan motor
Old Feb 9, 2010 | 10:53 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
In your first pic, the wires on the left that come out of the loom, the green/white wire is the fan trigger from the ecm. the brown/white wire supplies 12v to the relay. you'll need to find a plug for the relay and a relay
and wire it according to this diagram. the diagram is for the dual fans but the wiring is similiar.
I had to do this to my 86 when i first got it.
almost forgot, if your 86 is like mine it does not have a switch in the head, the fan is controlled only by the ecm
Old Feb 9, 2010 | 07:42 PM
Great. Good info man. Yup, I got a 86 IROC Z but there is no 305, I dropped in a 350 Power Plant. I always wondered about the switch that goes into the heads. Now I know that there is none. Thanks bro
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
krisner89
Oct 10, 2015 06:03 AM
Bert87
Aug 23, 2015 03:50 PM
