1985 burn off modulator
Old Feb 10, 2010 | 03:38 PM
mattyc's Avatar
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
ok, i think i have a new problem.
i was charging my battery today and i went to start it up and i heard a buzzing as the engine was turning over.(not the starter) the car never started up
so i pulled down the ecm and tried it again, the burn off modulator(i heard it also called maf controller/ relay) was buzzing when i was trying to start. I unplugged it and the buzzing went away.
as i turned the key it seemed that what ever charge the battery had seemed to vanish.
the car is an 85 z28 with tpi.
i pulled a code of 12, which was distributor reference pulse not detected or some thing along those lines. do they have anything to do with each other?
Old Feb 11, 2010 | 09:58 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: 1985 burn off modulator
Code 12 is normal, and will always be present. It comes from when you have the key in the on position without the engine running - there are no distributor pulses because the distributor is not turning.
As far as the buzzing sound, I'm guessing it was a relay inside the MAF burnoff module. I'm not exactly sure what you're asking though - are you saying that the engine turns over but does not fire up?
Old Feb 11, 2010 | 10:13 AM
mattyc's Avatar
Engine: 350 tpi
Axle/Gears: ???
that makes perfect sense, any ideas on the burn off buzzing when turning the engine over
Old Feb 11, 2010 | 03:48 PM
mattyc's Avatar
Engine: 350 tpi
Axle/Gears: ???
the car will fire up, i just never heard this sound before while charging a battery. its just that i would turn the key to start it up but i would get this buzzing sound, then what ever charge was in the battery seems do vanish.
fired the car up today and no buzzing.
Old Feb 14, 2010 | 08:15 AM
mattyc's Avatar
Engine: 350 tpi
Axle/Gears: ???
so nobody has any ideas,
InfernalVortex
Apr 20, 2021 11:31 AM
Lbibb
May 5, 2016 12:00 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
