Fuel Pump Question??
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I have a 1990 Camaro 305 tbi that I am installing a tpi setup from an 1989 Trans am on it. I know my Tbi fuel pump wont cut it so i found this fuel pump http://cgi.ebay.com/ebaymotors/ELECT...ht_2729wt_1165 I wonder if it will work and if so i plan on buying it. Heres what the listing says. Thank you to everyone
Unleaded Gasoline,
after 24 hr. break-in:
Pressure = 400 kPa About 45 PSI
Voltage = 12 V
Flow = 180 Min, 270 Max
Current = 11.5 A Max
Shutoff Pressure at 12V = 550 kPa Min, 900 kPa Max
Mineral Spirits (End of Line Test):
Voltage = 13 V
Flow = 180 l/h Min, 300 l/h Max
Current = 14.5 A Max
Shutoff Pressure at 12V = 625 kPa Min, 900 kPa Max
Unleaded Gasoline,
Voltage = 12 V
Voltage = 13 V
Car: 1990 Camaro RS
Axle/Gears: Posi
Re: Fuel Pump Question??
Isnt there anyone out there that could help me this seems like a good deal with the strainer and everything, and i just want to make sure its right for my application, thanks
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I'm guessing you could throw a fuel pump for a 5.7 liter in there and that should take care of it. That's what I did to my 305 TBI. I don't know about your regulator though. I got an ACdelco pump from rockauto pretty cheap!
Car: 1990 Camaro RS
Axle/Gears: Posi
thanks for the reply i was just wondering if this pump would fit in the sending unit then could i use it?
Who is ratrodzrus? Funny that their price is $45 with free shipping when reputable sellers charge about $100 for genuine Walbro pumps. Considering that Ebay is the home of hundreds of vendors that sell Asian made knock off auto parts, and knowing that Walbro pumps have been cloned by the crooks, I'd think twice before buying that pump.
Car: 92 sonoma
Engine: 1985 LB9 tpi, stock
Transmission: NV3500
Axle/Gears: g80, 4.11 posi
quick question... i wired up my tpi myself... is the fuel pump supposed to run while the starter is engaged? because it isn't... the pump runs when it stops cranking (not running) and when i shut off the ignition... the engine cranked for a second the other day and then quit... seems like for good.... but now i cannot get it to crank at all. i have timed it several times, then checked for spark, and i've got fuel and spark both times... the only thing i can think of is injectors not running... someone please help!!!
Last edited by 55mikey55; Feb 19, 2010 at 11:03 PM. Reason: my dumbass not thinking
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
