MAF Relays
Old Mar 16, 2010 | 05:49 PM
FJFOOL's Avatar
MAF Relays
Hello, I'm trying to find new power and burn-off relays, but having problems with the configuration. The harness I have calls for an oval shaped relay, 5 pin, 2 in one line, three in the other. Been to the dealer and napa, their relays are all 5 pin all in one line and rectangular. I bought one fuel pump relay on e-bay that is correct, p/n is 14103304. I had a 91 Suburban, tbi, that had this same relay, dealer said no, they all had the 5 pin in a row. Any ideas on this ? Thanks in advance !
Old Mar 17, 2010 | 05:27 AM
smier's Avatar
Car: 1986 IROC Z28
Re: MAF Relays
Need some more info on your car, what year it is, what motor, etc...
Old Mar 17, 2010 | 08:38 AM
Pocket's Avatar
Car: 91 Trans Am
Re: MAF Relays
Relays function the same, regardless of what style they are
If you correctly assign the wiring, a universal square relay will do the job
I would suggest upgrading to the later oval style relay because the old flat ones have a strong tendency to fall apart at the connector shorting the circuit out. You need the correct connector though. Grab one from a JY or PM me for a used original
Old Mar 17, 2010 | 12:39 PM
FJFOOL's Avatar
Re: MAF Relays
What I'm trying to find are the oval relays to fit my aftermarket harness plugs, all I can find are the square ones. Thanks, Alex
Old Mar 18, 2010 | 08:48 AM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
Re: MAF Relays
While this statement is true in a general sense, it is not true when it comes to the MAF power and burn-off relays. Do a search (on the TGO board) and you will find the results.
CG
Old Mar 18, 2010 | 12:10 PM
Pocket's Avatar
Car: 91 Trans Am
Re: MAF Relays
https://www.thirdgen.org/forums/dfi-...-yet-burn.html
True, but the question was about using oval relays in place of an older style. In this particular case, wire assignments and function are the same. Battery power in and relay out, call 12v and call grd. The only thing that changed was the relay internals. Its a matter of finding the proper PN for the relay
Old Mar 18, 2010 | 02:54 PM
Re: MAF Relays
Autozone, Advanced, Napa, etc should have the relays. My '87 has the "square" relays, but the oval ones should be very easy to find. Do a search for MAF relays in the TPI section and you will find the answers.
CG
Old Mar 18, 2010 | 03:04 PM
FJFOOL's Avatar
Re: MAF Relays
Thanks guys, the number I've come up with thru search is 14089936(power and burn-off). Since this is the stock number from the factory, I pressume that is AC/Delco ? This is the oval shaped relay. Sorry to beat this to death, I don't have a stock application so I'm just trying to find the correct relays for the oval shaped plugs. Thanks for all the help !
Old Mar 19, 2010 | 08:10 AM
Re: MAF Relays
Look up an '89 F-body for the oval style relays. Here is a link to Advanced for the MAF power relay. 14089936 is an OE number.
http://shop.advanceautoparts.com/web...S_568481144___
CG
Old Mar 19, 2010 | 10:28 AM
FJFOOL's Avatar
Re: MAF Relays
Thanks George, what I needed !!
Mark_ZZ3
May 24, 2018 01:02 PM
thunder57
Nov 7, 2015 02:28 PM
racereese
Oct 3, 2015 03:46 PM
