TPI harness and A/C
Old Mar 16, 2010 | 09:10 PM
chevy_camaro_ss's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 posi
TPI harness and A/C
I'm doing a swap from a 91 TBI to a 89 TPI system. Its been a while since I've messed with TPI but I got some questions.
1. Do the existing AC plugs/wiring go to the current TBI ECU or is that seperate. How will teh AC be affected by going with the 89 TPI Harness?
2. Is there some place where I can see the pin outs of the harness/ECU?
Old Mar 17, 2010 | 06:58 PM
Car: 1989 Camaro RS
Re: TPI harness and A/C
Any help is appreciated guys.
Old Mar 17, 2010 | 08:24 PM
dek1285's Avatar
the computer only uses the a/c as an iput not an output i believe. uses the signal to adjust idle when a/c is on. if im wrong someone correct me. but i will try and get you some pinouts for the ecm on here
Attached Thumbnails TPI harness and A/C-1989-tpi.gif   TPI harness and A/C-1991-tbi.gif
Old Mar 17, 2010 | 08:32 PM
dek1285's Avatar
the first pic is the 89 TPI pinouts and the second is the 91 TBI pinouts
stalkier
Dec 6, 2015 11:25 PM
IBrockZ
Aug 20, 2015 12:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
