5.7 tpi missing at idle and tru driving
Old Mar 5, 2010 | 07:41 PM
nightowls_gm's Avatar
Car: 88 IROC Z
Engine: 5.7
Axle/Gears: 3.27 9 BOLT POSI
its an 88 5.7 and its missfiring at idel and driving speed. my spark plug wires are new ant so are the spark plugs. the fuel filter was clogged but i did replace it and still nothing. any ideas what it might be? thanks for your help.
Old Mar 7, 2010 | 01:54 PM
360Iroc's Avatar
Re: 5.7 tpi missing at idle and tru driving
Did it do this before you you did the plugs and wires?
If not, did you drop a plug? Sounds dumb I know, but I dropped a plug when on our trailer, and curled the electrode in on the plug. Had to pull them all to realize this, because I didnt check the plug before I put it in.
If so, check resistance on your injectors.
Old Mar 7, 2010 | 11:49 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Also, check the fuel pressure. Are you getting spark? Can be a few things to check before you find the problem.
Old Mar 8, 2010 | 11:41 AM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Do a test on the injectors with a digital ohmmeter with them cold and warm. My GTA was doing the same thing and it turned out to be two bad injectors.
Good luck.
Old Mar 8, 2010 | 11:55 PM
Car: 88 IROC Z
Engine: 5.7
i did check the fuel pressure and spark. but i havent tested the injectors thats my next step. thanks i'll let you know how it turns out
Old Mar 9, 2010 | 07:34 PM
southbay08's Avatar
if you had a clogged filter you may have clogged/dirty fuel injectors.
www.southbayfuelinjectors.com
Old Mar 10, 2010 | 09:36 PM
Car: 88 IROC Z
Engine: 5.7
i checked the injectors and they all read 17.3 ohms. what does this mean?
Old Mar 17, 2010 | 11:06 PM
LS7Roc's Avatar
Car: 88Roc Flame Red Black/Gold Pkg
Means they're good.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
