TPI T.V cable part number??
Old Mar 19, 2010 | 10:15 PM
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
Anyone know it? I want to check at GM Parts Direct, or pick one up from the dealer.
I can get one from a T.B.I. truck, any chance it is the same as the TPI? I think the TPI is a little longer.
Scott.
Old Mar 20, 2010 | 12:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: TPI T.V cable part number??
The TPI cable is quite a bit longer.
In 87-88 it's 25521263, in 89-92 it's 10163879.
Old Mar 20, 2010 | 09:42 AM
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
The T.V. cable is cheap from GM Parts Direc!!
GM LIST: $26.39
OUR PRICE: $15.63
At that price, I could buy the throttle and cruise too!
Do you (or anyone else) know the numbers on the cruise cable and throttle cable??
Thanks!!
Old Jun 18, 2011 | 09:31 PM
john36mc's Avatar
does anyone know if this cable will work with a turbo 350?
Old Jun 21, 2011 | 10:31 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Won't work.
Old Dec 17, 2011 | 02:16 AM
fonzie85's Avatar
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
Won't work.
What makes the 700r4 not work on the TH350?
Old Dec 17, 2011 | 05:29 AM
john36mc's Avatar
i know the tuneport cable is longer. then the th350 cable. I ordered a Tuneport cable then removed the transmission cable end carefully. Then I had a old th350 cable and put the tranny end on the cable and hot glued it works great . I think the difference is the diameter of the cable where it goes in the transmission.
Old Dec 18, 2011 | 12:42 PM
fonzie85's Avatar
Car: 89 IROCZ
That's what I was thinking the diff was from looking at the. Pics and that was the exact same idea I had. Glad to know it works.... thanks for the help
1992 Trans Am
May 10, 2023 07:19 PM
twest2k2
Aug 24, 2015 11:26 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
