In line replacement TPI pump suggestion??
Old Mar 27, 2010 | 10:30 AM
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
I need a in line pump near the tank for my 5.7 TPI car. What would be a good pump that can supply the fuel I'll need? I have a tank to use from an non F.I. car, and sending unit to match, so that is all I'll have to pull through.
Thanks!
Old Mar 27, 2010 | 04:48 PM
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
Re: In line replacement TPI pump suggestion??
That's too bad. I really thought someone here would have an answer. Maybe MalibuRacing.com would have someone with a little knowledge about this problem. If I find out over there, I'll post it over here so if the question ever comes up again, they can solve a problm as well.
theshackle
Mar 5, 2017 06:37 PM
NBrehm
Aug 25, 2015 11:49 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
drathaar907
Aug 6, 2015 04:20 PM
