TPI.Hard start
Old Mar 27, 2010 | 04:43 PM
Uncle_Frog's Avatar
Car: 1986 Trans-Am/2005 Pontiac Grand Pr
Engine: TPI 305
TPI.Hard start
I have a 1986 T/A with the TPI and when I start it I have to hold the peddle to the floor and after it starts it won't idle but it will rev and when I put it in gear it stalls any idea's?
Old Mar 27, 2010 | 05:15 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
Re: TPI.Hard start
Mine does the same. I believe its a weak fuel pump. If my tank gets to under a ⅓ it has fuel delivery issues.
Old Mar 27, 2010 | 11:26 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: TPI.Hard start
Any trouble codes? Is the SES light on? hard start can be a few things but usually it's the ignition system. May need new wires, plugs, and new dizzy guts. Holding the peddle to the floor to get it to start means that when you give some pedal, your opening the throttle plates thus allowing more air into the engine, BUT, also you are opening up the TPS. So my first thing that I would so is tune up the TPI system. Here are two good links for you. Tune the TPI system, then get back at me if the issue is still there at hand. Good Luck bro.
http://74.125.155.132/search?q=cache...&ct=clnk&gl=us
http://mpikas.blogspot.com/2008/08/t...june-2000.html
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
