stock tpi on 383 will it work
Old Mar 29, 2010 | 12:02 AM
louflemm's Avatar
im broke the engine just needs an intake. 383 procomp 210s,eagle stoker kit, summit flat tappet .488 int .510 exh, i just want to know if my 305 tpi setup will run the 383 until i get money cause its just sitting. my 305 is costing me money it burns so much oil runs like crap. i know it would not go past 4000 rpm but could i drive it until i save up
Old Mar 29, 2010 | 12:18 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: stock tpi on 383 will it work
make sure the intake ports on the heads are not too tall. i don't know if it would idle correctly either. not sure if it would work at all.
Old Mar 29, 2010 | 12:25 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
I don't think it will ... to clarify you have a 305 and it's busted... so you want to drop in an engine you have laying around? ... you will have to connect all of the sensors that go with it... depending on whether your cam is ECM friendly, otherwise it will try to compensate leading to problems... that's if it even idles... your injectors on a 305 are 19 lbs.. on a 383 I think you would need at least 30 lb injectors not sure though... the 305 prom would also cause problems... I would say no... interesting though if you could though... keepING ...
Old Mar 29, 2010 | 05:02 AM
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
my friend has a 383 with the stock tpi, but he bought the car that way, so no idea what injectors, tune or cam he has.
so the answer is yes, if the tune and injectors and cam all match up accordingly.
Old Mar 29, 2010 | 09:01 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Yes you can as long as you get the intake base to seal up to the heads properly.
It will run but not all that well without proper adjustments. Stock 305 TPI intakes/injectors have been run on 406 cube engines. If all the sensors are hooked up right the feedback algorithm will work the same. The ECM doesn't know the actual size of the engine or the actual fuel pressure or injector size.
If you can make adjustments in the PROM you can get it adjusted pretty close. If not, then you can make up some of the discrepancy by raising the fuel pressure by about 20 - 25% (+7 to 10psi).
A switch to 24 lb/hr injectors will also get you close.
Once you change the fuel pressure or injectors you should unhook the battery to force the ECM to relearn the BLM's quicker.
With the stock injectors I wouldn't run the engine at WOT, but driving it around would be fine.
Old Mar 29, 2010 | 03:35 PM
if money is a concern you'd be better off with a carb setup. see if someone has something laying around or you could trade your tpi.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
NBrehm
Aug 25, 2015 11:49 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
