Difference between Camaro and Firebird?
Old Mar 30, 2010 | 05:32 PM
Travis Criag's Avatar
Im rebuilding my 91 TBI camaro RS to a TPI setup. I bought a wiring harness, ecm, intake and that good stuff from ebay for a good price. my problem is i cant remember what year and model the TPI stuff is from. After all the research ive done using the prom and ecm numbers ive concluded that it is from a 90-91 firebird. Now, that i have installed everything there seems to be some problems the biggest being i have no communication between my ecm and my ALDL connector. I am using a snap-on scanner and know that it is working correctly. I am wondering if there is any difference in wiring between a 91 camaro and a 90-91 firebird? I wouldnt think there would be but i am all out thoughts so any helo would be greatly appreciated!!
Old Mar 31, 2010 | 09:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Difference between Camaro and Firebird?
At the ALDL connector the '90-'92 TPI uses a different pin then the '88-'92 TBI.
If still using the original ALDL connector move pin E to location M.
RBob.
Old Apr 1, 2010 | 12:05 PM
Hey!! thanks a bunch worked like a charm!!
Frozer!!!
Jan 19, 2024 04:55 PM
onefreakz
May 14, 2018 12:15 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
antares57
Aug 6, 2015 07:47 AM
MENINBLK
Aug 5, 2015 11:58 PM
