Distributor with Vortecs question
Old Nov 25, 2009 | 06:12 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Does anyone know a part number for the small cap hei distributor that is needed when swapping to Vortec heads/manifold?
Thanks for your part number(s) and recommendation(s).
Old Nov 25, 2009 | 07:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Distributor with Vortecs question
Nothing special about the Vortec intake ;takes regular distributor
If you want a small cap version then just get one from a F body or TBI truck
MSD #8366 if you are feeling rich
Old Nov 27, 2009 | 11:31 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
With the Stealth Ram, you have to get a small cap distributor and a remote mounted coil, so I've read. It also looks like the plugs on the smaller diameter distributor are different than the plugs on my current distributor. I wonder if the wires are the same colors on the new plugs. I could probably find the distributor, coil, and ignitioin plugs/wires for that distributor in a junk yard. I'm gonna look.
My first goal for today is to get the Hedman shorties I have on the hated 305. I just chopped the y-pipe and pulled the stock paperweights out of the engine bay. I finally found the ambition to do it. I didn't even have to jack up the car.
Old Nov 27, 2009 | 11:42 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Although I don't have any personal experience I did some research a while back and apparently the later, small cap modules have an additional ground lead. The attached may help some:
http://www.megamanual.com/ms2/GM_7pinHEI.htm
Let us know how it goes.
Old Nov 27, 2009 | 04:38 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Thanks. I'll cross the bridge when I come to it and just figure it out as I go, most likely.
Old Nov 27, 2009 | 05:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by New2Chevy
It also looks like the plugs on the smaller diameter distributor are different than the plugs on my current distributor..
If you have a HEI dist and want to change to a small cap (which is what you should have said 1st up ) you can get a $15 adapter harness to connect your existing large harness plug and a plug with pigtail ($10) to hook up the remote coil from
Mike
www.eficonnection.com
Old Nov 27, 2009 | 06:59 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I thought it was known that I needed to switch...I wasn't clear? I guess not. Sorry.
Thank you for that information. Very useful!
Mike
Old Nov 27, 2009 | 07:11 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Ok, I looked at the site. What all will I need from them?
Old Nov 27, 2009 | 08:17 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
http://www.eficonnection.com/eficonn..._pigtails.aspx
The large to small cap adapter ; 5th down LH side
Mike is not showing it on the page but he has the small cap dist coil plug ( white - pink pigtails ) Just ask him
Say I sent you
Old Nov 27, 2009 | 08:28 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
I have everything you need for the swap if you are interested. I have a MSD small cap dizzy, remote GM blaster coil, and the harness $125.00 plus shipping. I had a vortec stealth ram, but have since sold it.
Let me know if you are interested
Jason
Old Nov 28, 2009 | 02:01 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
PM Sent. What are you running now?
Old Nov 28, 2009 | 02:32 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
I am building a carb'd 377ci. So i am switching to a large cap HEI unit.
Old Mar 31, 2010 | 10:47 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
You're right. I forgot to mention that I am putting a Holley Stealth Ram on top of the heads, and that is why I need the small cap distributor.
Old Apr 1, 2010 | 12:40 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
If you are going to buy msd 8366 go to msd forum, and search corrosion etc. problems
http://www.msdignition.com/forum/forumdisplay.php?f=8
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
