L98 Temp Gauge
Old Mar 25, 2010 | 01:28 PM
LS7Roc's Avatar
Car: 88Roc Flame Red Black/Gold Pkg
L98 Temp Gauge
The temp gauge on my car doesn't move. Stays at the cold position all the time. I removed the dash plate and when I touch the needle, wherever I put it, it stays. Also, when I turn my ignition on, sometimes the passenger side fan will run, sometimes both will run. After I start the car, both fans will run continously. Need some help with yet ANOTHER problem!
Old Mar 26, 2010 | 12:13 PM
LS7Roc's Avatar
Re: L98 Temp Gauge
Old Mar 26, 2010 | 03:12 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: L98 Temp Gauge
temp guage runs of a sending unit in the drivers side head, look below and between the first two spark plugs near the front, there should be a green wire clipped on to it.
are the fans running a new problem or has it happened right along?
could be bad relays, or something shorted to ground.
Old Mar 26, 2010 | 03:19 PM
LS7Roc's Avatar
Re: L98 Temp Gauge
The problem just started. What should I check?
Old Mar 26, 2010 | 04:06 PM
Re: L98 Temp Gauge
Check the relays and all the wiring, look on the radiator support near the battery for the 2 relays.
The primary fan is controlled by the ecm, the secondary is triggered by a switch in the pass head, seeing as both fans run all the time I would switch out the relays first, they're probably old and corroded
Old Mar 28, 2010 | 11:23 PM
LS7Roc's Avatar
Re: L98 Temp Gauge
Thanks John...I'll try that out.
Old Mar 31, 2010 | 10:53 PM
LS7Roc's Avatar
Re: L98 Temp Gauge
OK guys...got it working..I replaced the temperature sender (aka engine temp sensor) and it's giving me a reading! BUT, both fans come on within a minute...sometimes the driver side fan stops but the passenger fan continues non stop. If I disconnect the relays of course, they shut off. The relays are very clean and not corroded at all.
Old Mar 31, 2010 | 11:06 PM
LS7Roc's Avatar
Re: L98 Temp Gauge
Anyone?
Old Apr 1, 2010 | 02:22 PM
blakecharles's Avatar
Re: L98 Temp Gauge
My fan never comes on at all, this is a good read... anyone else have advice?
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
86IROC112
Sep 11, 2015 04:04 PM
