350 TPI Dual Fans Keep Running
Car: 88Roc Flame Red Black/Gold Pkg
Minute after starting my car, the passenger side fan comes on then the other fan comes on. Sometimes I think both come on at the same time at startup and never shut off??
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: 350 TPI Dual Fans Keep Running
are you saying they keep running while the car is running? one fan is controlled by a fan switch, the other is controlled by the ECM, and I am not sure but I think that one of the fans kicks on when you have your AC on... but not sure... I'm just trying to give you some ideas...
Car: 1989 Firebird Formula
Engine: 5.7 LS1
the fan on the drivers side always runs, the 2nd fan comes on when the coolant temp sensor tells the ECM at a certain temperature to kick on (I believe 228 is the max temp the computer is set at that tells the second fan to kick on, when the car first runs through it heat cycle for the first time after being started, and yes the ac also kicks on the fan as well, makes the engine run a bit cooler.
Car: 1989 IROC-Z
Transmission: Th700R4
The driverside fan should come on at approx 215-225 F (depending on wich PROM you have)
The passengerside fan is controlled either from AC Pressure switch or if the engine reaches ~238F (it will engage the secondary fan (passerngerside))
Regarding your issue have you changed something recently ? When did this problem occur first time. The fans shouldnt run all the time. Only if the temp is reached or if the AC pressure switch grounds it (when ON) the fan on driverside shouldnt come on unless it have reached the correct temp for it.
Both fans will run if you have used a paperclip to bridge the ALDL connector to view errorcodes, but when the paperclip is removed they shouldnt start.
You have to check your fan wiring to see if something is grounded. You have manual switches for the fans ? if yes, have the wiring for them checked and tested.
Car: 1989 IROC-Z
Also a failing PROM can cause the fans to run constantly, but then the car would run bad or die sometimes. chugg etc.. when my EPROM went bad my fans kept running, replaced the PROM and it solved that problem (but first check your wiring and relays to the fans)
How do I check the relays? The wiring seems okay, no tears or broken wires. Relays are clean.
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
If a relay were to short internally it could be stuck in an on position, but this is highly unlikely, they tend to fail the other way, and not turn the fans on, which is what happened to me once.
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
That's called limp home mode
Car: 1989 IROC-Z
