"Need Help" My Car Turns On Fine Stumbles and Dies If I Dont Push The Accel. For Gas
Old Apr 6, 2010 | 01:48 PM
emmanuel33v's Avatar
Car: 1986 Camaro Iroc Z28 (Corvette 5.7)
Engine: 1987 Corvette 5.7L TPI
Transmission: TR400
Axle/Gears: Stock
I have a 1986 Camaro with a 350 TPI and I am having difficulties when it starts and when I drive it around I have to keep the gas pedal in becuase if i dont my RPM's go below 500 and car dies" my car is an automatic and i have to drive like if it was a manual transmission car giving it gas when it get to a red light other wise it turns off.
Any Suggestions or Help Would Be Great
Thank You
Old Apr 8, 2010 | 12:49 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: "Need Help" My Car Turns On Fine Stumbles and Dies If I Dont Push The Accel. For
Thank You
Hello emmanuel33v!!
Check your EGR valve for sticking, or being siezed, and check out your IAC valve, for being dirty/inoperative!!
Old Apr 8, 2010 | 07:50 PM
87TPI-5SPD-TA's Avatar
Replace the IAC, my car just went through the same thing.
Old Apr 8, 2010 | 09:18 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Before you go replacing parts, try adjusting the IAC for min. air, as well as setting the TPS sensor to a proper reference voltage. While you are at it, check the timing. If it starts but needs more open "throttle," (not gas), then it could be something as simple as an adjustment to one of these sensors. There are detailed tech articles on this subject located on the TGO homepage.
Will
Old Apr 10, 2010 | 01:33 PM
Transmission: TR400
Axle/Gears: Stock
Would you know were can I open the Throttle From?????
I have No Idea I just bought this car like 2 months ago....
Old Apr 11, 2010 | 03:39 PM
norcalz28's Avatar
Opening the throttle means " giving it gas." although on newer cars you are not actually giving it more gas, you are increasing the amount of air passing into the engine by OPENING the throttle blades. Check timing, check TPS adjustment, and reset the IAC.
Old Apr 11, 2010 | 04:49 PM
puddingmmmmmmmm's Avatar
Car: 05 CTS-V
My car is having the same issue, except I have to hold in the gas pedal to start it, and once it starts if I let go off the pedal it just stumbles and dies.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Sherpajames
Aug 7, 2015 06:56 PM
