need help with cold start problem/fuel pressure issue
Old Apr 7, 2010 | 03:10 PM
87_gta's Avatar
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
Hey all, i have used the SEARCH and couldn't find an answer to my question.
i have this problem, its been this way for a while.
When i start the car cold it doesn't want to idle, i have to feather the gas just a touch to bring the revs to say 800 rpm and it will idle but it tends to spurt out black stuff from the pipes. When the car is warm i only have to wait maybe a min then i'm good( when warm no black stuff)
Yesterday i went to check the fuel pressure, removed the vac line with the gauge on and it idled perfect (about 50psi no vac) stayed running. when i connect the vac line back up. started to idle rough again and then died. Before it died i saw about 32-35psi with the vac connected.
Also i don't know if this is related but sometimes if say i'm at a stop and floor it, car jumps, practically stalls out and then comes back and goes np. this doesn't happen all the time but often enough.
help would be appreciated
thx.
Old Apr 7, 2010 | 09:46 PM
LS7Roc's Avatar
Car: 88Roc Flame Red Black/Gold Pkg
Re: need help with cold start problem/fuel pressure issue
thx.
Well, how long since the last tune up? Could be anything really.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
