How do I solve Edelbrock Intake and Runners vacuum leak??
Old Apr 7, 2010 | 10:04 PM
motleykent's Avatar
Car: 1987 Chevrolet Camaro Iroc-Z
Transmission: B&M 700R4
Hey everyone.
I just had an Edelbrock intake manifold, runners and Holley throttle body installed on my 1987 Camaro and am having a problem with the gasket between one of the runners and the manifold. Apparently it is causing a vacuum leak, and it seems like I need a thicker gasket between the two surfaces. Has anybody come across this before, and would you have any suggestions? Do you know of a gasket set that may help out?
We tried the FelPro GM gaskets first, and the leak was really bad. Then we tried the Edelbrock ones that came in the kit, and it is better, but it still leaks.
I also had to get a throttle body spacer to move the throttle body forward as the IAC housing (coolant tube) was hitting the passenger side runner. I know most projects don't go smoothly, but it would be nice for a change too
Thanks for any help you can give me.
Attached Thumbnails How do I solve Edelbrock Intake and Runners vacuum leak??-1.jpg
Old Apr 7, 2010 | 10:17 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: How do I solve Edelbrock Intake and Runners vacuum leak??
Originally Posted by motleykent
Hey everyone.
when you tightened everything down, did you tighten it in a criss cross pattern? The way you tighten the lug nuts?
Old Apr 8, 2010 | 12:10 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
The gasket should be plenty thick. Although, it wouldn't be the first time an "edelbroke" piece has made it out of the factory with a less than perfect fit. I would make sure the plastic pins that come in the gasket are seated in their respective holes, and not sticking out and keeping it from sealing. I am running old accel runners, a ported plenum with scars in the aluminum, and I don't have any vacuum leaks. If you can't get it to seal up, I might think about sending them back.
Will
Old Apr 8, 2010 | 12:23 AM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
match your gaskets up to the Edelbrock TPI runners, if i recall correctly you need to run 2x driver side (or vice versa) plenum gaskets with the Edelbrock runners.
Old Apr 8, 2010 | 10:24 AM
motleykent's Avatar
Thanks guys. I will give this a shot this weekend and see how it goes.
Old Apr 8, 2010 | 11:03 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
also make sure that the EGR is not preventing the Plenum from sitting where it's suppose to sit....
Old Apr 8, 2010 | 08:05 PM
motleykent's Avatar
I see what you mean about the gaskets. I thought I would have a look at some pictures that I took before putting the runners on my car to compare them to what you were talking about. The Edelbrock runners have the same shape on both sides. Nice how they don't even supply the correct gaskets in the kit :|
Now I know what to look for. Thanks again everyone for the help.
Attached Thumbnails How do I solve Edelbrock Intake and Runners vacuum leak??-1.jpg   How do I solve Edelbrock Intake and Runners vacuum leak??-2.jpg
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Infested
May 22, 2018 11:56 PM
Zeek1041
Aug 21, 2015 08:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
