89 iroc z
Old Apr 8, 2010 | 04:34 PM
89IROC-Z89's Avatar
89 iroc z
I have been reading your forum and its great. I finally decided to join. I have an 89 camaro 305 tpi the car turns on but idles really rough then turns off. then the check engine light turns on. it smells like unburned gas right after it turns off. the car will also not respond when i turn it on n push the gas but nothing happens. Whats wrong with it?
Old Apr 8, 2010 | 04:37 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: 89 iroc z
could be a bad injector..or MAF problems..unplug the MAF and see if it will run.
incase u dont know
the MAF is the plastic peice in the middle of the Intake hose.
Welcome to TGO
Mikey
Old Apr 8, 2010 | 04:50 PM
89IROC-Z89's Avatar
Re: 89 iroc z
did not work it did the same thing it has no throttle response. I replaced 4 injectors last year. Any other ideas
Old Apr 8, 2010 | 09:22 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: 89 iroc z
Check for vacuum leaks. Sounds like this might be your issue. If you replaced injectors last year, maybe you left something loose. When did this problem start? I would also check fuel pressure to make sure the pump is ok, then I would adjust the TPS and IAC sensors. Amazing how many guys are having rough running issues this week. Must be the nice weather and everyone's bringing their cars out. Anyway, there are a couple things for you to start with. Also check for a bad ground, there are only a couple, but if one is not connected to a good ground or the wire is cut, it could cause some driveability issues.
Will
Old Apr 8, 2010 | 09:34 PM
89IROC-Z89's Avatar
Re: 89 iroc z
The last couple days when i started the car the check engine would turn on but would later turn off after it warmed up. I did not replace the injectors i had a shop do it. I will go n check out some of your suggestions. Thanks for the help guys.
Old Apr 8, 2010 | 09:36 PM
norcalz28's Avatar
Re: 89 iroc z
read out your ses code, that could point you in the right direction at least.
Old Apr 8, 2010 | 10:06 PM
89IROC-Z89's Avatar
Re: 89 iroc z
Is that the trick with the paper clip? Where is the list of the code read outs?
Old Apr 9, 2010 | 10:44 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
Re: 89 iroc z
Originally Posted by GM tuners .com
GM OBD-1 Diagnostic Trouble Codes
For 1995-previous model year EFI-equipped GM vehicles. NOTE: Some codes not supported on all models, consult your specific vehicle's service manual for the correct trouble code list and description for your application.
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
DTC - 41 Ignition control error
DTC - 41 MEM-CAL error
DTC - 41 C³I Cam Sensor Signal error
DTC - 42 Ignition bypass circuit error
DTC - 43 Knock sensor error
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 44 Left bank O2 sensor error (lean condition indicated)
DTC - 45 Oxygen sensor error (rich condition indicated)
DTC - 45 Left bank O2 sensor error (rich condition indicated)
DTC - 46 Pass-Key II (VATS) system error - circuit out of freq range
DTC - 47 UART (serial data) circuit error
DTC - 51 PROM error
DTC - 51 Incorrect MEM-CAL
DTC - 52 Fuel cal-pak incorrect or missing
DTC - 53 System voltage too high
DTC - 53 Digital EGR Valve solenoid 1 error
DTC - 54 Fuel pump circuit low voltage
DTC - 54 Digital EGR Valve solenoid 2 error
DTC - 55 ECM error
DTC - 55 Digital EGR Valve solenoid 3 error
DTC - 56 Quad Driver Module (QDM B) error
DTC - 57 Boost Control error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS system error
DTC - 59 Trans fluid temp sensor circuit error (high voltage)
DTC - 61 A/C system performance
DTC - 63 Right bank O2 sensor circuit error
DTC - 63 MAP sensor circuit signal voltage high (low vacuum indicated)
DTC - 64 Right bank O2 sensor lean exhaust indicated
DTC - 64 MAP sensor circuit signal voltage low (high vacuum indicated)
DTC - 65 Right bank O2 sensor rich exhaust indicated
DTC - 66 A/C pressure sensor circuit error (low pressure indicated)
DTC - 67 A/C pressure sensor circuit error
DTC - 68 A/C clutch relay circuit error (shorted to ground)
DTC - 69 A/C clutch relay circuit error (open circuit indicated)
DTC - 69 A/C high pressure switch error
DTC - 70 A/C pressure sensor circuit error (high pressure indicated)
DTC - 71 A/C evaporator temp sensor circuit error (low temp indicated)
DTC - 72 VSS signal circuit error
DTC - 73 A/C evaporator temp sensor circuit error (high temp indicated)
DTC - 75 Digital EGR solenoid #1 circuit error
DTC - 76 Digital EGR solenoid #2 circuit error
DTC - 77 Digital EGR solenoid #3 circuit error
DTC - 79 Transmission fluid overtemp
DTC - 80 Transmission component slipping
DTC - 82 3x Crankshaft position sensor circuit error
DTC - 85 PROM error
DTC - 86 A/D error
DTC - 87 EEPROM error (flash memory error)
DTC - 90 TCC error
DTC - 93 Transmission pressure control solenoid circuit error
DTC - 96 Transmission system voltage low
DTC - 98 Invalid PCM program
DTC - 99 Invalid PCM program
Old Apr 9, 2010 | 07:37 PM
southbay08's Avatar
Re: 89 iroc z
If you only replaced 4 injectors, you might want to check the others, especially if they are the stock multecs! When you replace fuel injectors, you are better off replacing the whole set because eventually you will have to replace all or most of them anyway.
Check the resistance with an ohm meter, pull the plugs if you have wet cylinders you have leaky injectors, or they may just be clogged/dirty.
You can check your sensors also.
www.southbayfuelinjectors.com
Old Apr 9, 2010 | 10:57 PM
89IROC-Z89's Avatar
Re: 89 iroc z
I started the car today n while it was cold i was able to give it gas with no problems it was running fine for about a minute or two then it just turned off. Could it be the injectors since it just came out of nowhere. it ran perfectly fine last week with no misfires or anything. The car only has about 77K miles on it. could it be the ignition module. i really dont feel like spending 100 bucks on each injector.
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
mustangman65_79
Aug 23, 2015 02:00 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
